Old 06-21-2011, 03:53 PM
wall23b wall23b is offline
Vehicle: 2011 Dodge Ram SLT
wall23b is on a distinguished road
Default Tire monitor System
Hey,
I just have a general question about the tire monitor system on my 2011 1200 SLT hemi 4X4...
It looks like on the guage that all tires are diffrent? could this be possible or is this the way it's spose to be? it was like this when i got it from the dealer.
I'm not 100% sure on how it works but i would think that all 4 numbers should read the same?
Thanks
Mark
Old 06-21-2011, 04:28 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Originally Posted by wall23b View Post
Hey,
Thanks
Mark
It's nearly impossible (if not impossible) to fill each tire to exactly the same pressure. A couple psi difference is common.
Old 06-21-2011, 04:41 PM
Rep:2657
I went to a large tire store, they sell TPMS also
they had a electronic device that they hold next to the valve stem when the key is turned on, the electronic signature reads out on the device
The TPMS lets your vehicle know when a tire is getting a bit softer than what is recommended
You still need to check the sticker on your drivers side door for the proper tire pressure & inflate accordingly at regular intervals
Old 06-21-2011, 05:51 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Hey,
Thanks
Mark
Three of mine are the same and one is different. When I start driving the tires diagonal to each other are the same, the others are different. In the manual it states that even with the system you need to check your tire pressure regularly. Basically its their disclaimer telling you not to rely on the system entirely.
Old 06-21-2011, 06:01 PM
Thanks for the replys very helpful !!!
Old 06-22-2011, 12:29 AM
nikeman nikeman is offline
Rep:91
My car came from the dealer with 50 PSI in all 4 tires. It seems high but I have not one anything about it as of yet. Is 50 to high? I have the good year tires if that makes a difference.
Old 06-22-2011, 12:51 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Yes 50 seems high. The sticker on the door jam will tell you how many PSI to run. I think 44 PSI is the max. I try to keep mine at 38PSI.
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
I think if you check on the inside of your door you should be about 35psi
Old 06-22-2011, 07:33 AM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
35 PSI is what it says on the sticker, but I also run mine at 38-39 PSI, they seem to run better at that level.. just my 2 cents.
Old 06-22-2011, 02:19 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I have mine at 40. I think at 35 the warning indicator kicks on that they are low, IIRC.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 91 05-06-2015 04:41 PM
Aerosol Tire Spray "Spraying" on fenders after applying and driving!? RammD Dodge Ram Detailing and General Maintenance Forum 17 02-21-2013 09:40 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 10:25 PM
