Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 06-23-2011, 07:37 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
I did my front Rams head with the plasti-dip, and I have been blinded by that chrome ring one to many times, I have been meaning to dip it as well.
Like mentioned just prep with alcohol and let it dry, this stuff will actually peel of and leave the part unharmed.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 07-07-2011, 10:10 PM
caswell239 caswell239 is offline
Vehicle: 2011 Ram 1500 Sport Crew
Color: Deep Water blue pearl
Rep:20
caswell239 is on a distinguished road
You brush it on?
Old 07-08-2011, 12:52 AM
Bulldawg1359's Avatar
Bulldawg1359 Bulldawg1359 is offline
Vehicle: 2010 Dodge ram
Rep:25
Bulldawg1359 is on a distinguished road
You could brush it on, but it doesn't work too well like that. Plasti dip can be found at ACE Hardware and Home Depot for like $6. ( I got mine from ACE cause Home Depot was all out.) It comes in a spray can and a "dipping tube" thing for dipping tools in. Purchase the spray can. Prep is easy. Just clean of the surface and mask everything off. Then spray at a reasonable distance. It doesn't drip too much. Do a couple of coats and it should be fine. Plasti dip can come in a variety of colors but I used flat black. I plasti dipped my chrome grill on my sport and the results were amazing. Now the top grill matches the bottom. Here are some pics. I am a painting rookie and I did a great job with ease. It has been a couple of weeks now and I have been driving on the highway and in extreme Georgia heat. The plasti dip has held up very well. Also, if you make a mistake (say you got it on the car paint) it will come off with rubbing alcohol or nail polish remover. Overall Plasti Dip is a great invention and you cant really go wrong with it! I am thinking of doing my emblems and even my wheels with it. Hope this helps!! Best of luck!
White Lightning
My story - http://www.ramforumz.com/showthread.php?t=117311
Georgia on my mind.
Old 07-08-2011, 05:41 AM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
Yup sprayed on. I would never do wheels. The stuff is too rubbery i think. The dirt would stick bad i would think.
Old 07-08-2011, 11:11 AM
Rep:25
Your may be right. Perhaps I would need to spend the time to actually paint them. I went to NAPA and they had all kinds of specific wheel paint. If not that, then it looks like I am saving up for real wheels
White Lightning
Georgia on my mind.
Old 07-31-2011, 05:14 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I finally have had it with my chrome shifter bezel blinding me in the sunlight. I took it off tonight and Plasti Dipped it. I think it turned out great. This stuff is pretty easy to work with.
+1 for you!
I did mine today and I couldn't be happier with the result.
After the first coat I notice a few small bumps on my bezel, just gently scratched them off with my fingernail (after it dried of course) and shot it again.
3 coats in all and it looks like it was pooped out by an angel.
Thanks for the tip!
Old 07-31-2011, 06:06 PM
rtkman's Avatar
Rep:167
Lol is that good? :-)
Old 08-01-2011, 07:17 PM
am33 am33 is offline
am33 is on a distinguished road
I did mine a few weeks ago also. Great, easy mod.
Old 08-03-2011, 12:42 PM
nicslaw's Avatar
nicslaw nicslaw is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Forest Green
Rep:15
nicslaw is on a distinguished road
To get the bezel off just get your fingers under it to start then work your way around. be carefull it could break but its not too tough to get off. I've seen the shadow chrome at Canadian tire.
I started mine with a putty knife as it was pretty tight. There are several holding points under the lip and each are notched with several grooves to hold it in place. A little pressure at each point working around the bezel will release it without worry.
I found 2 coats was plenty after it was cleaned. The first coat had a lot of "orange peel" effect, but the second coat filled in nice and smooth.
Old 08-10-2011, 01:45 AM
euromade euromade is offline
Gender: Not Specified
Vehicle: 2011 Quad Cab 4.7
euromade is on a distinguished road
I'd like to paint the "chrome" sides of my center console around the radio. Do not like the mix of the black, tan and chrome interior! If I could make it black n' tan it would be nice!
It is an SLT package with some fake chrome arround the vents as well and the center console.
Finally, Is this stuff durable when it comes to heat/cold? Up here in Michigan we get 100 deg summers and then sub zero winter.
P.S. I just picked up an upgrade OEM touch screen myGig system, so I guess I could take care of the plastidip while I'm installing the head unit.
Thanks...
Center Bezel Removal 09-11 moparornocar72 Dodge Ram Knowledge Base 30 07-21-2013 06:05 PM
Plasti Dipped PW RBPPowerWagon Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 18 11-23-2011 06:12 AM
Plasti Dipped bumper RBPPowerWagon Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 6 06-11-2011 08:41 AM
2006 Factory NAV bezel scott06hemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 11-29-2010 04:44 PM
Ram Replacement Shifter? Texas Hemi 2009 Dodge Ram Forum 7 03-11-2010 12:20 AM
