Recon LED tailgate bar problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-22-2011, 08:20 PM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
Default Recon LED tailgate bar problem
Hey all, I have a 2010 Ram 1500. I installed a Recon White Lightning tailgate bar about a year ago and it worked great. Then I installed Recon LED smoked tail lights. That is when my lightbar went nuts.
Heres the problem: When I turn on the left/right turn and hazard it works fine. If I turn on my headlights the light bar no longer works. If I only turn on the headlights, the light bar flickers. I was told to install a resistor, and did so with no luck. Just fooling around, I turned off my fog lights and it worked, kind of.
I have talked to a few people and can't find an answer. I have gone around and around trying to figure this out with no luck. Please help!
Old 06-22-2011, 08:37 PM
Color: Mineral Gray
Rep:36
PS, I have it hardwired in. I have pulled a tralier and have had no problems what so ever with the lights working on it.
Old 06-26-2011, 04:05 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
What resistor value did you install ??
Was it/they 6 ohms?
brad
Interested in one of my mods?
Old 07-09-2011, 08:05 AM
Color: Mineral Gray
Rep:36
Yea, it was the 6ohms. I think it may be a problem with the light bar itself though, because the 7 pin harness works fine when a trailer is plugged in.
Old 07-09-2011, 08:38 AM
brad12kx's Avatar
Rep:2581
If it's hardwired into the trailer wiring circuit, then it's either a light bar issue, or a wiring issue. Take a look at the ground wire connection before you write it off.
brad
Old 06-18-2012, 09:34 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
I got the recon tails on order and this light bar how would I hook this light bar the guy at recon told me hook it up to the 4 pin connector and run the one wire to back up lights on the tails But I'm reading places of the 7 pin connector. I just want the easiest and one that will not expose any wires cuz the connectors are in the front
Old 06-18-2012, 09:44 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i would check all ur connections again and make sure there all good to go and even remove the tail lights to make sure the bar still works normally.....did you contact recon about this issue? maybe they have herd of it before and have a solution to the problem
Recon Tailgate bar epeitz Electrical 4 06-22-2011 08:41 PM
connecting led tailgate lightbar emmyshemi Electrical 1 04-27-2011 04:20 PM
Recon LED taillights not working shaneG Electrical 5 04-23-2011 05:33 PM
Recon LED taillights question southpaw5m Electrical 1 04-12-2011 03:26 PM
LED turn signal problem southpaw5m Electrical 7 02-09-2011 06:24 PM
