Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 06-23-2011, 06:13 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The earlier the better! I did mine at 10,000, wish it would have been at 3,000...runs smoother! Amsoil OE synthetic for me!
Old 06-23-2011, 06:17 PM
moose3 moose3 is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew w/Rambox
Color: Deep Cherry Red
Rep:36
moose3 is on a distinguished road
This is about the 3rd time in a week that I have seen Amsoil touted as Ester based. It is good oil, I am even considering running it, but people on the forum need represent products correctly.
Old 06-23-2011, 07:04 PM
highlandchef's Avatar
Conventional Eccentric
Rep:220
In all truth I'm not sure there are any pure Group IV PAO based or Group V Ester based oils out there for automotive use. PAO based oils contain some Ester oil and visa-versa. Redline is rumored to contain as much as 35% PAO stock but of course they're not saying. Both PAo and Ester stocks are excellent oils but both have drawbacks as well. Blending the two helps deal with their respective drawbacks creating an oil that is better than either alone.
Old 06-23-2011, 09:41 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Default oil
Sorry about that slip on amsoil folks, You are correct,,,,had to go back and read.Here is some infohttp://www.waynesgarage.com/docs/synthetic_oils.htm
Old 06-24-2011, 09:03 AM
Vehicle: 2011 Ram
Rep:36
I work in the powersports industry, and esters are a very well established part of the market. That most likely is a result of the fact that motorcycle oil is also the transmission fluid, so esters being more durable on the molecular level than PAOs. Polymer chain break down is a major issue there.
Old 06-24-2011, 10:44 AM
Rep:220
Esters are definitely better for high heat applications as mentioned where motors reach temperatures not seen in everyday applications. Also in racing and powersport applications the oil is never used for a long enough time to experience the downsides of esters.
Old 06-24-2011, 10:49 AM
Clifton's Avatar
Clifton Clifton is offline
Vehicle: 2011 Dodge Ram 1500 Crew 4x2
Trim Level: Lone Star
Clifton is on a distinguished road
Ive always used AMSOIL is my vehicles. I plan to switch to it on my first oil change. Is there a better product than AMSOIL for the 5.7 Hemi? I know little about the make up of synthetic oils... any help is appreciated.
2011 Ram Hemi Crew White - DynoMax VT Muffler - Drop in K&N - De-Badged - Spray in Bed Liner
Old 06-24-2011, 12:02 PM
Color: Blue
Rep:55
Default oil
Here is some info to read. I use Redline in all my vehicles. http://www.waynesgarage.com/docs/synthetic_oils.htm
Old 06-25-2011, 12:06 AM
nikeman nikeman is offline
Rep:91
I am seeing 3 different types of Mobil 1 5W-20 oil... Which of those 3 do you guys use? 2 of them are full synthetic while the 3rd is not..
Old 06-25-2011, 12:15 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Had my first oil change done by the dealer 2000 miles ago plan on let the dealer do my next and around 10.000 I will start to do my own oil change as usual for my vehicles. planing to use AMSOIL since it has good recommendations from others RAM users especially here on the forumz.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
1st Oil Change BLKSPORTHEMI Oil Change 41 10-12-2011 07:53 PM
Oil change info needed on a 03 Ram 5.7 zmurphy 5.7L V8 Specific Topics 3 05-27-2011 01:55 AM
Dif oil change believe or not? uktitus Dodge Ram General Discussion 1 05-23-2011 12:15 AM
oil change chrisisbored24 Oil Change 24 05-11-2011 06:43 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
