Old 06-23-2011, 02:30 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
Default 6 speed transmission
full press release included with the article..
http://www.autoblog.com/2011/06/23/r...-transmission/
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 06-23-2011, 10:22 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
So it's only for HD Ram. Nothing for the Ram 1500.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 06-24-2011, 01:04 AM
terb's Avatar
terb terb is offline
Vehicle: 2014 Ram 2500.........6.7
Rep:17
terb is on a distinguished road
The HDs have had six speeds starting in 2007 when the 6.7 came out..
2014, 2500 crew cab with 6.7
Old 06-24-2011, 11:04 AM
The Hemi had the 545rfe, but for 2012 it will have a new 6 speeds.
Old 06-24-2011, 11:39 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
This may not be related at all, but I heard dodge was going to have a flash to make the current 5 speed that has the 2nd prime gear into a 6 speed....no sure this would help at all as they are almost the same gear though...
Sean
Old 06-24-2011, 04:50 PM
I wish it's true. It would give us a better third gear then the new 65rfe and 66rfe.It sure would help around town.
545rfe
1-3.00
2-1.67
3-1.50 (second prime made into third)
4-1.00
5-0.75
6-0.67
65rfe, 66rfe and 68rfe
1-3.23
2-1.84
3-1.41
4-1.00
5-0.82
6-0.63
I don't know if a good tuner could actually make it work as a 6 speeds?
Old 06-24-2011, 04:55 PM
snrusnak's Avatar
Rep:1385
so is the 65rfe and 66rfe, and 68rfe the new 6 speed in the HD? I don't know but someone in another thread I read said that if you use the manual shift button to put the truck in gear, instead of "D", it adjusts the shift pattern as you show above, moving the second prime in place of third, and third in place of fourth, etc...
Sean
Old 06-24-2011, 06:09 PM
68rfe has been in the HD truck for a couple of years.
The 65rfe and 66rfe are the new transmission. From what i've read, 65rfe was suppose to be in the 1500 serie and 66rfe was for HD with Hemi engine.
Both 65rfe and 66rfe are 545rfe casing with 68rfe gears.
Anyway, that's the information i was able to get on internet.
Old 06-27-2011, 11:36 AM
65rfe = Reprogram 545rfe to use all 6 gears.
66rfe = 545rfe with 68rfe gear set.
http://news.pickuptrucks.com/2011/06...smissions.html
Old 06-27-2011, 11:39 AM
snrusnak's Avatar
Rep:1385
so that means I could get a flash or something so my truck will use all 6 gears? This wouldn't have a negatives would it...?
I also saw somewhere that the 45rfe(4 speed) was able to be reflashed to be the 5-45rfe(5 speed)
Sean
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
5 Speed Transmission and Spark Knock Issues **URGENT** iil1ill 5.7L V8 Specific Topics 3 05-24-2011 05:26 AM
ZF 8 Speed Automatic Transmission Coming Soon RamTech Dodge Ram General Discussion 6 02-04-2011 10:53 PM
2007 Ram 1500 5 Speed Auto Transmission Landngroove 5.7L V8 Specific Topics 2 09-20-2010 06:03 PM
Where is my automatic transmission speed sensor? padleout Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 4 03-28-2010 03:01 PM
