Old 06-23-2011, 09:29 PM
Rob Wallace Rob Wallace is offline
Rep:22
Rob Wallace is on a distinguished road
Default Track bar relocator bracket
Hey all. I have the Belltech 2/4 drop on my 2010 Ram and when I got my new rims put on the right rear wheel sticks out about half an inch. I'm thinking the axle is off a little to the right. Well as you know the only company that carries the bracket I need to relocate my track bar is McGaughys and they will not sell it separately. So my question is how is the track bar relocated? Is the driver side mount lowered down to match the passenger side? Any pics please? Thinking about making me one...
Old 06-23-2011, 10:31 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I did some research into this also when I lowered/leveled the rear of my truck. Ended up not needing to do anything...prob b/c I only lowered it about 1.5" but check out this link. I was going to order this custom adjustable track bar (panhard bar). Remove and replace your stock one with one of these and you can adjust (shorten/lengthen) the bar to center up your rear axle.
http://www.spohn.net/shop/Custom-Par...ed-Length.html
Old 06-23-2011, 10:44 PM
Rep:22
Thanks but by looking at the dimension pic it looks non-adjustable...and it says fixed?
Old 06-23-2011, 10:51 PM
CHVYKLR's Avatar
Rep:252
dohhh...fail on my part. I'll try to find the correct link. sorry.
Old 06-23-2011, 10:52 PM
CHVYKLR's Avatar
Rep:252
this should work.
http://www.spohn.net/shop/Custom-Par...djustable.html
edit: you will prob get more NVH from the spherical ends.
Old 06-23-2011, 10:55 PM
Rep:22
Thanks I will try that thanks!
CHVYKLR's Avatar
Rep:252
this one has poly ends and so you don't get anymore NVH.
Old 06-23-2011, 11:15 PM
Rep:22
Well I put in the dimensions and ordered it. Came out a little over $200 shipped. Thanks will take pics when installed.
Old 06-23-2011, 11:18 PM
Rep:22
Should I get the second one instead?
Old 06-23-2011, 11:25 PM
CHVYKLR's Avatar
Rep:252
the spherical bearings won't ever wear out but the poly bushings will def ride a little better. I don't know how much NVH the sphericals will make on our trucks. I think if it was me I'd call them first thing in the morning and ask for the poly bushings.
take some pics when you get it. I know there are a couple of others in your boat.
Drag Racing Tips dodgeman70592 Drag Racing Discussion 32 04-26-2014 10:33 PM
mygig HDD playlist and track playback davidreed Dodge Ram General Discussion 1 06-22-2012 01:06 PM
First track visit garner Dodge Ram R/T 22 09-02-2011 01:44 PM
upgraded track bar? SportHD Suspension 1 05-31-2011 02:58 PM
Big Yellows day at the track! Brian08 Dodge Ram Pictures - Photos 9 08-04-2009 05:59 PM
