Old 06-23-2011, 09:27 PM
TVDOC TVDOC is offline
TVDOC is on a distinguished road
Default Hemi vs Cummins
Ok, so I just got back from a 1300 mile trip through the Appilacian Mts towing a 10,000 lb trailer with my 2010 Ram 1500 4x4 Laramie. I had beefed up the suspension with air bags inside the rear coil springs and E rated tires to provide that little bit of insurance for the 980 lb tongue weight. Gas mileage with the Hemi was 7.9 mpg burning 89 - 92 octane. I monitored the oil temp, trans temp, etc and sometimes it got a bit warmer than ideal but for the most part, not too bad. Pulled hills pretty good and never really ran out of power although engine RPMs sometimes were pretty high. All in all, it performed better than I expected and so here is the question...
How does my Hemi (390hp w/ 425 ft/lbs of torque) match up to the Cummins (350hp w/ 800ft/lbs)? I mean, if I traded my truck in for a 2500 Cummins, what would be the noticeable difference? I pulled the long hills with no problems, the ride was smooth, and it didn't feel like it was ever getting away from me. Is the 2500 Cummins worth the price differential? I pull this trailer 4 or 5 times a year about 1000 miles each time. The rest of the time, its a no load trip to the office and back. Give me some input. I'd like to hear from the veteran haulers.
Old 06-23-2011, 09:57 PM
karlak karlak is offline
Vehicle: 2004 Dodge Ram
karlak is on a distinguished road
I believe if you did a back to back test you would buy the cummins.
Old 06-23-2011, 09:59 PM
I think you'd find the Cummins will pull the trailer easier due to the torque of the engine but there's a trade off...the Cummins will have a higher maintenance cost.
If I was towing that load all the time I'd go to the Cummins but 4 or 5 times a year really doesn't justify the higher acquisition cost nor the increase in maintenance costs.
Your HEMI can handle that load just fine.
Old 06-23-2011, 10:17 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I would maybe consider a 2500 Hemi instead of the 1500. Their timing/tune is different then the 5.7 in the 1500s
Old 06-23-2011, 10:39 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I'm with Maddog. If you are only pulling it 4-5 times a year I'd stick with the 1500. The 2500 won't ride as nice, diesel fuel isn't cheap and the diesel motor comes with a hefty price tag.
4th gen HEMI is 390hp/407q...but who's counting.
Old 06-24-2011, 10:23 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I also will agree with Maddog; the Cummins will definitely pull better but for a few times a year it's probably not worth it. The rest of the time the Hemi is less expensive and more civilized.
Old 06-24-2011, 11:00 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Is the truck also your daily driver? If so, how far do you drive on average each day?
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-24-2011, 11:23 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Wouldn't it be cheaper to just by a $300 tuner than a 2500?
I know the diffs are better too, but for engine tuning that's a simple fix.
I bet you could buy a lot of goodies for the price difference, starting with intake,exhaust and a tuner.
I dont tow with my 10', but I tuned it from a 15 sec truck to a 13 sec Beast with those most basic mods.
Old 06-24-2011, 11:44 AM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
Hey BlackRamHemi, whats the deal with the 180* stat?? I'm just curious if you're running it to keep things cooler on the strip or whats going on there?
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 06-24-2011, 01:39 PM
Rep:554
Yes mainly for the track, I can add more timing and more power with my tuner with a cooler running engine.
Very popular cheap $27 fix to drop a couple tenths for most who know drag racing
I do run it all year round though, even in cold Canadian Winter temps (-35º) with no negative effects.
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
Cummins or Hemi? TEXASHEMI50 Dodge Ram General Discussion 10 03-01-2011 09:33 AM
HEMI to Cummins agood6000198 Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 5 02-19-2011 12:05 AM
changing 1500 to 2500? hemi to cummins agood6000198 Cummins Diesel Specific Topics 18 01-13-2011 10:50 PM
