Old 06-23-2011, 10:18 PM
666's Avatar
666 666 is offline
Vehicle: 2012 Dodge Ram Sport
Color: True Blue
666 is on a distinguished road
Default 2011 Ram remote start
I recently bought a new ram 1500 ST. i didn't get the factory keyless entry or remote start. I usually just install an aftermarket one. I have been looking at the Viper 5501. I have went to a couple place around town and they have told me different things for what parts i need. I will be installing this myself because shops around here charge extra for every little thing. I have installed many compustars before in various vehicles.
So my question to you guys is, What bypass modules will i need to run just the command start and keyless entry?
I have the black ignition key that has a square bottom and says "Ram" on it.
Old 06-27-2011, 11:36 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 06-27-2011, 11:46 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
I had a buddy that works at best buy do mine, ST model as well. Went with an Avital, hit it once and it starts, hit it again and the drivers door unlocks, double tap it and all doors unlock....not the range of the Vipers, but it's like 1/4 mile. I'll get with him tomorrow and get you some numbers, should be the same as mine.
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 06-28-2011, 11:11 PM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
You are going to need a "DBALL" by Xpresskit, which is made by directed electronics which make the Viper alarm. This device will access the CAN and send most of the digital signals needed for start, and also will provide power locks, as well as the RDIF key security code. These aren't terribly hard to hookup, because multiple wires from the alarm/autostart brain get hooked to this device, and it relays this info onto 1 wire(CAN). Any good installer will "bench wire" all devices first, tape the multiple harness needed and then install. I think the new technologies make this easier, as thinner gauge wires are needed as you and the auto start aren't actually starting the vehicle, the computer is....
Old 06-28-2011, 11:56 PM
666's Avatar
666 666 is offline
Color: True Blue
thanks for all the info.
i might just get it hooked up at bestbuy. they are selling the cipher for $299 including basic install. i don't get any money off if i install it myself so i might as well get some of it hooked up for me.
Old 01-05-2013, 08:22 PM
WHITERAM80 WHITERAM80 is offline
WHITERAM80 is on a distinguished road
Default Remote Start
Hey 666,
I am planning on installing a viper aftermarket keyless/start on my Ram ST next week. I got the DBALL to interface with it.
I was wondering if you ended up doing this yourself or not?
If you did where did you hook up the accessory wire? At the TIPM module?
Also any tips?
Thanks in advance
Old 01-05-2013, 08:44 PM
666's Avatar
666 666 is offline
Color: True Blue
Yes I did it myself. You won't need any accessory wire. You just run a ground and constant to the dball. The data 2 data supplies the viper with all power needs. It's stupid easy to do. I would get a couple of the tap connectors for the door trigger makes it easier
Old 01-06-2013, 06:33 PM
Default Connections
Thanks 666. Now bear with me i am relatively new to this and thought i had it figured out, but its seems not. On my install sheet the from the dball it says to connect the viper to ground and 12v.
Anyway could you tell me what connections you made to the dball and the viper? Also where did you connect you 12v power. To the battery or the factory 12 pin node harness
Thanks a lot
Old 01-06-2013, 06:59 PM
EXPRESSIVE EXPRESSIVE is offline
Rep:49
EXPRESSIVE is on a distinguished road
I usually do everything myself also, but I brought my truck to a shop to have the muffler installed. They did it for $50 and I thought that was worth NOT dragging out the MIG!
Old 01-06-2013, 11:00 PM
666's Avatar
666 666 is offline
Color: True Blue
I just looked at my install again. The power and ground do go to the command start. The dball takes it's power from the command start and the t harness. Got myself all confused lol. I know my astro start needed two wires for the door trigger. Not sure what the viper needs. I have a website that has all the wire diagrams for any Chrysler. I will look for it in my bookmarks. Also when I ran the 12v and hood pin wire to the engine bay I unplugged the grommet for the hood latch cable and ran it through there. Made a nice clean install.
NewB Problem with Remote Start TexasParamedic Electrical 6 10-31-2011 02:14 PM
RKE and Remote start billzthe1 Electrical 13 07-23-2011 01:38 PM
Remote start does not work with low fuel sportcrewMI 2010 Dodge Ram Forum 10 11-22-2010 11:18 PM
Remote start question... barkboxx 2010 Dodge Ram Forum 3 10-20-2010 05:16 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 09:27 PM
