Old 06-23-2011, 11:06 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
Default rear differential question
i have a 95 ram 4x4 with the 5.2 and i believe 3.55 gearing and open rear diff. i am sick of getting stuck in everything because of this one wheel spin crap, my friends truck came with a factory limited slip in his ram. could i just find the same rear end as hes got and put it in my truck so ill have limited slip? or would it be cheaper and easier to buy a kit and put it in? also, how would i determine if a truck has a limited slip differential in it or not? what would the stamp on the differential say if it were a limited slip so i know what to look for in junk yards? thanks!
Old 06-24-2011, 08:37 PM
Color: inferno red
can anyone help me out here or what?
Old 06-24-2011, 10:14 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
there is a way to tell by lifting the axle off the ground and spinning one wheel and if the opposite wheel spins in the opposite direction it means something, but I can't remember what....someone else will know....I think it means its open diff....
Sean
Old 06-24-2011, 10:35 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Correct, one in each direction is open. LSD wheels will turn the same way
Old 06-24-2011, 10:39 PM
snrusnak's Avatar
Rep:1385
good teamwork....
Sean
Old 06-25-2011, 10:00 PM
Color: inferno red
is this the only way? is there a sticker on it anywere that will say it so i dont have to go jack up every truck in the yard to see is its got it or not. and how would i know what gear ratio it has?
Old 06-25-2011, 10:33 PM
Rep:2583
If i remember right
older vehicles had a sticker in the glove box
but, i know that is one of the first things that are removed or tore out to get to the heater
i know, i'm not much help when it comes to this subject
Old 06-25-2011, 11:16 PM
916Timmy's Avatar
Rep:1443
You could get a limited slip for about 300-500 bucks, then install it. I looked at the setup for mine and it was about 1400 for a true-trac, new gear ratio and install!
Old 06-25-2011, 11:39 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:127
Well if you have only one wheel spinning then that means it's isn't Limited Slip, what LSD is Posi-Traction. Anyways it's cheaper to buy a Posi-Trac Differential and put it in but be sure when you do gear oil changes that you use LSD additive, and put the additive in before the gear oil. Anyways if you have the chrysler 9.25 which you probably do because of the year and axle ratio then you can just buy a LSD off ebay. just search "chrysler 9.25 posi" and you will show something to affirm this the truck has a chrylser 9.25 you can request a build sheet (if you give me your vin I can get you one within 24HRs, or you can look under the hood for a vehicle sticker that has info such as the axle ratio, torque converter, transmission etc.
Just remove the differential and put the ring gear from the old one on the new one and install the new differential then put the additive in and then the gear oil. And boom you have posi trac. Over time you will have to replace the clutch pack on the differential. Their is another guy on ebay with on for 89 bucks I think but it needs new clutches. But hey it would be cheaper to rebuild it then to buy a new one. Anyways have fun, good luck. Any questions I'm here to help.
Old 06-26-2011, 09:03 PM
Color: inferno red
ya i know i have a 3.55 gear ratio with a open diff. so would it be easier and cheaper to buy the lsd kit off ebay and just put it in my rear end? or go find a whole rear end at a junk yard and swap the whole thing?
would i need the ring pinion gears off ebay or the whole lsd thing thats 300 bucks or so?
Rear Differential Noise shocker Dodge Ram 4x4 - Offroad Discussion 8 03-24-2011 11:07 PM
Rear end question ajay080672 Dodge Ram General Discussion 7 10-21-2009 09:10 PM
Rear end bearing question donniehall1 Suspension 1 10-18-2009 09:02 PM
anti-spin differential rear axle Andy37 Newbie Checkin! 6 06-14-2009 03:17 PM
Anti-Spin Differential Rear Axle Andy37 Dodge Ram General Discussion 3 06-12-2009 05:32 PM
