Old 06-26-2011, 11:27 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
Originally Posted by ramvan2500 View Post
The 360 only has like 20-30 more HP. Your transmission might need a good band adjustment. You should be able to do a burn out. I mean like... you should just be able to, it's odd to not be able to. I've seen Dodge Ram Van's with the 318 do it all stock. Well first try changing out the differential, maybe that will help
what the hell is a band adjustment? cause if that would help me out i might do it. cause sometimes it feels like this thing cant even get out of its own way. and i know this truck has some balls but its like something it holding it back!
oh and nobody ever answered me, if i change the gear ratio in the back i have to change it in the front also right?
Old 06-27-2011, 01:44 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Originally Posted by The Codes View Post
thats a wicked burn out!
I know, and thats not even my van. I won't do a burn out in my van, it will damage the transmission and puts unneeded ware on the motor. I don't mind a transmission waring much because you I rebuild it over and over but a motor can only be rebuilt so many times before the block has to be scrapped.
Old 06-27-2011, 01:54 AM
ramvan2500's Avatar
Rep:128
Band adjustment now I think of it I'm not sure if your tranny has bands in it, they stopped using bands a long time ago. Anyways bands are just metal bands with friction material on them, they rap around metal drums in the transmission that have a combination of steel and friction plates in them that make up clutches, their is a forward band and a reverse band. The forward band is the first gear while the reverse band is the 2nd and 3rd gear along with reverse. That is if the transmission we are talking about is a 3 speed. Anyways I think you don't have bands because of the age of the vehicle, I'm so use to old fashion stuff that I just say bands. haha
Anyways, the motor and transmission do have something to do with not being able to do a burn out because you just saw a god damned van do it but that van did have posi I believe they put posi on their, im putting posi on my van cause I remember when I was ten the van got stuck in the sand so their ya go. Anyways I think it's time you have the transmission serviced, I am not gonna lie but chrysler transmissions are good but only if you use approved ATF+4 and service the transmission regularly. If you do service it regularly then I can promise you atleast a quarter million miles off a transmission without any slippage. At one point if you were dealing with bands you would have to have the bands replaced which is very easy and requires basic tools and a transmission fluid pump seal and gasket kit and two bands.
Anyways I'm getting ahead of myself here with transmission repairs and rebuilds which I can do in my sleep. (Motors and transmissions are just puzzles and them I am good at
anyways start out by putting a LSD and having the transmission serviced, watch them put the transmission fluid in (many mechanics just put in Dex 2 and you don't really want to use that, it's cheap the dollar store sells it down here where i live, but they don't sell chrysler atf. So make sure they use CHRYSLER Approved ATF+4 (Valvoline) and watch them pour it, they will try to cheat you. ALWAYS do your own oil change also because the jiffy lubes like to save a quart of oil. they use to short my parents on a quart of oil and my mother found out and they were doing it to all there customers, amazing the place is still there. Dex is not made for chrysler thats why it's no good. Anyways I say have the trans serviced because many people actually don't service their transmission (fact based on statistics) anyways that and because I know you must of had a rebuild because you stated the engine and transmission have about 70K miles on them so I'd figure a vehicle with 200+K miles and a trans and engine with 70K miles he must have had a rebuild.
Old 06-27-2011, 06:55 AM
Color: inferno red
ya i just bought the truck last year and the guy i got it from said it had 65k on the motor and trans and said its got the heavy duty trans it it. so i got somwere around 70-75k now. and ya i know all about the ass holes working at quik lubes! that why i will never got to one!! so when you say have my trans serviced what do u mean? just have the fluid changed or what?
Old 06-27-2011, 03:30 PM
ramvan2500's Avatar
Rep:128
Well by servicing, usually it involves a fluid and filter change but sometimes if you want to get a good servicing it would be a fluid flush were they hook up a fluid exchanger to the cooler lines and then flush it out, now I doubt you need to do that because of the mileage and you can usually tell by the colour and oder of the fluid. Also a service is mainly band adjustment if you have bands, it is recommended to have the bands adjusted every 12K miles but you have to remember 12K miles in respect to how you drive (meaning towing, WOT, and so on)... But first just check the dip stick and do this.
Take a white paper towel and let a drop of ATF from the dip stick drop on the paper towel, if the ATF spreads outward then the transmission fluid hasn't been worn out yet, if it spreads this means that it's still a friction modifier and not a just liquid.
Then check the colour it should be a redish pink, if it's brown or has some slight brownish in it, then the fluid must be flushed, this means that the fluid has been burnt.
Now for the fun part, check the oder. If the fluid has a burnt like toast smell to it then thats obvious, flush the fluid.
Now for the filter change, you can buy a filter and pan gasket kit for about 6.99 (mine is a 46RH and it's 6.99 for the kit (not bad) )
Don't use RTV sealant with transmission fluid, RTV isn't impregnable to ATF. I prefer to use a rubber gasket and put a little atf on each side of the gasket, helps with keeping it sticking to the pan when installing and just helps with the sealing. Then make sure the bolts are torqued to 13 ft/lbs. It is important they are torqued because overtime they do infact come loose because of the material of the transmission housing and the vibration from driving. Mine came loose most likely because whoever did the work didn't torque them properly, I was able to remove the bolts with my finger, usually the front bolts come loose first.
Well, anyways have the transmission just serviced but check the condition of the fluid first. Note that if your transmission has bands they will end up probably changing the fluid and filter because the pan has to be removed in order to adjust the reverse drum's band.
All that aside, get a LSD. You pretty much just have to swap the ring gear from the old one to the new one. Like the other man said you can change the ring gear and spider to have a much better axle ratio.
Old 06-27-2011, 03:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Wow good info there ^^^
Some comments: I've always heard you should never flush a transmission because it can contaminate it....so I've never done it. I've always done the gasket, filter, and fluid changes and seems to make them last much longer those people I know that never do it...That being said, I also drive easier usually, it almost hurts me when I'm with someone and they go in reverse about 5mph then throw it in drive...
Sean
Old 06-27-2011, 03:52 PM
ramvan2500's Avatar
Rep:128
It won't contaminate anything, when they do a fluid flush is really a fluid exchange they suck the old fluid out and then begin to cycle new fluid in. A majority of the transmission fluid is in the transmission itself and mostly in the torque converter. So when they cycle the new fluid in they even change out the fluid in the TC. What I mean about fluid in the transmission is that their is fluid above the valve body that can't drain on it's own without the transmission being on and in Neutral or without the help of a machine to extract the fluid. But a fluid flush is actually a very good thing because it helps with getting out fluid that is trapped in areas that you can't drain.
Certainly it is obvious to drain the pan and clean the magnet first before doing the fluid exchange else wise you have particles circulating all over the place.
Old 06-27-2011, 08:17 PM
Color: inferno red
thanks alot for the good info.im guna take it in tmrw and have it looked at by a trans guy and see what he thinks.
Old 06-27-2011, 09:44 PM
ramvan2500's Avatar
Rep:128
Sounds like a plan, just make sure they use the chrysler approved ATF and don't use RTV sealant for the pan gasket. Else wise it should be fine.
Rear Differential Noise shocker Dodge Ram 4x4 - Offroad Discussion 8 03-24-2011 11:07 PM
Rear end question ajay080672 Dodge Ram General Discussion 7 10-21-2009 09:10 PM
Rear end bearing question donniehall1 Suspension 1 10-18-2009 09:02 PM
anti-spin differential rear axle Andy37 Newbie Checkin! 6 06-14-2009 03:17 PM
Anti-Spin Differential Rear Axle Andy37 Dodge Ram General Discussion 3 06-12-2009 05:32 PM
