Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 06-24-2011, 12:05 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:21
ND RAM is on a distinguished road
Default Manual Shifting???
Ok, just when I thought I had it down about shifting my 5 speed auto manually this is what's happening.
Before I start out I set the manual shifter at 4th gear so it doesn't go beyond that.
However, when I take off starting in low it will go to 2nd., then 3rd. and stay there. It will not go into 4th.
If I set it at 3rd. gear it will go to 2nd. and stay there.
Now I know I didn't forget how to count.
If I just use Drive it will keep shifting up all the way to 5th.
What Gives
18" Magnaflow, AVS Vent Visors, Black Rectangular Running Boards, Access Lorado Box Cover, Access Bed Mat, W.Tech Mud Flaps, W.Tech Tailgate Tech Liner, Hitch/Hook, Hitch/Ball and 35% Front Side Windows Tint.
Old 06-24-2011, 12:15 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
You're catching the 2nd prime short shift, the evic doesn't have an indicator for it though so it reads it as 3rd.
2nd prime is also used as a kick down (passing gear) when your at highway speeds
545RFE Gear Ratios:
1st 3.00:1
2nd 1.67:1
2nd Prime 1.50:1
3rd 1.00:1
4th 0.75:1
5th 0.67:1
Reverse 3.00:1
If you use Tow/Haul mode it does the same thing 1-2, 2-2pr, 2pr-3 in a quarter mile run , even though the evic reads 4th
Here's a vid I shot last year with my Bully Dog GT and you can hear the 2nd prime shift
and here's what it looks like on the Tach...
Old 06-24-2011, 01:08 PM
vtelvr's Avatar
vtelvr vtelvr is offline
Vehicle: 2011 Ram Express
Trim Level: Express 1500
vtelvr is on a distinguished road
I have noticed this too. Thanks for the clarification BRHemi!
Old 06-24-2011, 03:37 PM
raydulce raydulce is offline
Trim Level: Big Horn or Sport
raydulce is on a distinguished road
So this is likely a dumb question, but what is '2nd prime'?
Old 06-24-2011, 03:43 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
unless i'm mistaken, it's lockup..
no loss between the torque convertor input/output
ya i think i'm mistook
if it's something that does occur on the track it can't/shouldn't be cuz lockup shouldn't happen under that kind of a load
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 06-24-2011, 03:45 PM
Correct ^^^^ !!!
Old 06-24-2011, 03:59 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
k i guess i'm not mistook...
here i was editing and i was right all along.."doh"
still, weird it would lockup under a "drag" style load...maybe just old skool thinking anyway but the only time you could get lockup (C5, 904, 200, 350 etc etc) was when you were driving granny (like when getting ECO to kick in)
Old 06-24-2011, 04:10 PM
estoltz estoltz is offline
Vehicle: 2011 Dodge Ram 1500 5.7 4x4
estoltz is on a distinguished road
So is there one in 4th gear? I notice that when I shift to 4th gear it drops slightly (like 250RPMS) and then shifts into 5th.
Old 06-24-2011, 04:27 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
i believe 5th gear itself is again a lockup
hope i'm not gonna shoot myself in the foot here BUT IMO all this talk of 5 and 6 speed trannies is bunk, i'm thinking they're mechanically 4 speeds with multiple lockups
like the old A4LD by ford was 1-2-3-OD with a lockup in 3rd and OD...did that make it a 6 speed too? same for the 200R4 and 7004R
i'm puzzled too by the ratios..in pristine conditions sure but if you're under any kind of load there's a loss to that ratio in the slipping of the torque convertor...the ratio becomes variable except when IN lockup as it becomes 100% mechanical
like when they came up with these numbers did the remove or add the hydro factor when they deemed it convenient or....
k, my brain hurts
Old 06-24-2011, 04:45 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Now I'm intrigued....can you guys explain the lockup stuff more.....lol
Sean
2003 Ram - 5Speed Manual hard shifting 4e6ypax 5.7L V8 Specific Topics 19 06-12-2011 10:07 PM
Owners Manual Ogreboy 2011 Dodge Ram Forum 5 05-06-2011 07:34 PM
Manual Shifting M.Scipione 2011 Dodge Ram Forum 10 03-08-2011 08:24 PM
manual shifting at full throttle and no rpm drop off??? miketen07 5.7L (345 cu in) HEMI V8 Specific Topics 0 02-13-2011 01:36 AM
Manual shifting question? Ray 2010 Dodge Ram Forum 6 03-12-2010 12:43 PM
