Old 07-21-2011, 09:13 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Well there's really two issues with the gear swap and the auto trans. First of all, you want to stay out of overdrive at the track because you don't want to be running wide open throttle in overdrive, it puts alot of stress on the trans. The other thing is highway cruising rpm. the taller the gear, the higher the rpm (and possibly worse mpg). For my setup, going with 4.56" only puts me at roughly 2200rpm if I remember correctly, that's not that bad, right now with 3.55" I'm at like 1,600 I think (this is all at 70mph). As for the 6 speed manual trans, I'm not sure what the ratios are, and not sure if it has the same issues with running wide open in the overdrive gears.
Sean
Old 07-26-2011, 01:23 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
Snru, what size tires are you running to get that? I just took my 37" tires off and put on 33" tires and im at 2400 rmps at 70mph
Old 07-26-2011, 01:25 PM
snrusnak's Avatar
Rep:1385
The calculated diameter of my tires is 32.5" roughly, it's probably more like 32" measured in the driveway. I used 32.5" for my calculations for whatever reason. Sounds like you have 4.56".
Sean
Old 07-26-2011, 06:05 PM
Rep:17
Yes I do, 2400 bad for the motor? Kills gas milage its good in town compared to when the 37" tires were on but anything above 65mph guzzles it down.
Old 07-26-2011, 07:17 PM
snrusnak's Avatar
Rep:1385
Not really that bad, I ran my old ford with a 3 speed on the highway alot at around 2800 rpm at like 65mph, never hurt it at all. the lower the rpm the better, but I wouldn't worry about it, just don't cruise much past 70mph. I'm still searching for someone that maybe makes like a 4.3 or 4.3 gear but can't find anything else between the 4.1 and 4.56
Sean
4.56 gears LSD What Should I Buy? millertime3900 2011 Dodge Ram Forum 5 06-19-2011 01:52 PM
LSD Differential Redlongbed 5.9L V8 Specific Topics 3 05-04-2011 06:20 AM
Can 3.92 and LSD be separate in Ram orders? chrismeyers2k1 2011 Dodge Ram Forum 8 03-10-2011 10:36 PM
LSD 3.55 gears BigHorn 4 Life 2010 Dodge Ram Forum 14 12-16-2010 11:44 AM
Is there a way to tell if I have a LSD? GeauxHunting 4.7L PowerTech V8 Specific Topics 12 10-16-2010 09:22 PM
