Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 07-12-2011, 06:41 PM
NORFLA71's Avatar
NORFLA71 NORFLA71 is offline
Vehicle: 2008 Ram 3500
NORFLA71 is on a distinguished road
Fixed now and is stronger than factory. They put extra spacers at every bolt (front and back).
Stock, for now...
Old 08-02-2011, 12:21 AM
bgbluram bgbluram is offline
Vehicle: 2008 RAM Hemi QC
Color: Sunburst Orange
bgbluram is on a distinguished road
At least they fixed it. Can you post after pics for comparison?
2008 Hemi 1500, 3.92, 2010 20's Plasti-dipped, KR Fab Sliders, FlowMaster Exhaust, Hella 500FF's
Old 10-05-2011, 02:16 AM
turborich turborich is offline
Vehicle: 2005 Dodge Ram quad cab
Color: blue
Rep:17
turborich is on a distinguished road
I have installed hundreds of fifth wheel and goose neck hitches. I have seen worse but I can tell you that the spacers should have been put under the ribbed section of the bed between the rails and bed with the bolt running though it. The second bolt that is going through the high part is fine (no spacer needed inside the bed but may require one underneath. Also I see the bolts are going through the "hat" section of the bed underneath without any spacers. There should have been round long spacer that go inside of the hat section and then the bolts will drop through them, this way as you tighten the bolts you won't crush the bed or hat section. Bottom line is that you can't have threads showing between the rails and nut underneath, the space needs to be shimmed up and torqued down. On some of the trucks you need to cut the sheet metal flange under the bed near the inside fender to allow the spacers to fit. I have found that the Dodges really need to be measured 100% dead on or you will be boring the holes out.
I have seen a few guys cut corners and do some real half assed and dangerous installs just to save some time. In the end it's never worth it! I have been told several times to not use spacers, shims, etc as they were too difficult to get in there but I did anyways & if the boss got upset I would ask him if he wanted his truck rigged up like this? If you need to charge another hour for labor it's better than screwing it up.
Good to hear they fixed it for you. If they didn't they would have been fools as that's a huge liability going down the road.
Old 11-03-2011, 08:36 PM
danimal danimal is offline
danimal is on a distinguished road
thats why i installed mine myself, i dont like other people touching my truck
you can never be sure they know what they are doing
Old 12-05-2011, 11:29 PM
moparguy62 moparguy62 is offline
Vehicle: 2012 Ram 3500 single wheel
Color: Black & Silver
moparguy62 is on a distinguished road
They just tried to sell me a hitch and install it! I decided to do it myself as most the time I pay to have stuff done its not right and I'm not happy. So I took a day to install a 12 pullrite superglide and did it in 4 hrs. I know its done right!
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 09:47 PM
grant wheel install? tinniste 079 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 10-26-2010 09:27 AM
5th wheel rail install jmann Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 08-13-2010 10:35 AM
3500 fifth wheel install tbart16 Towing 6 05-17-2010 09:00 AM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 04:56 PM
