Old 06-24-2011, 07:17 PM
DougDoug DougDoug is offline
Vehicle: 1999 Dodge Ram 2500 4x4
DougDoug is on a distinguished road
Default Truck will crank but won't start
I have a 1999 Ram 2500 5.9 4x4 that will crank but not start. I've replaced the PCM, plugs, wires, cap & roter, and ignition coil. Any suggestions? I'm at a loss.
Old 06-24-2011, 07:44 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Best bet is to take it one thing at a time, not just start replacing parts you don't know if they are bad or not. First of all, any check engine light? Second, check for spark. Third, check for fuel pressure. Fourth, check compression. If all these are good it should run.
Sean
Old 06-24-2011, 09:28 PM
I agree with that ^^^^.
Welcome to the forum and good luck!
Old 06-24-2011, 09:36 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Have you double checked the rotor cap? I replaced one once when i did plugs and wires and put that sucker on 180 degree out. Took me forever to figure out when she wouldn't start. Once I turned it around the way it was meant that truck fired right up like a champ.
What made you replace all that stuff in the first place?
Old 06-25-2011, 11:09 AM
It was running rough so I gave it a tune up, and it ran great for about 5 or 6 weeks. Then it just quit running while I was driving it one day. Ended up having it towed to a shop, they said it was the computer, so I replaced that, and it didn't make any difference. I;m going to double check the roter, then on to compression.
Old 06-25-2011, 12:38 PM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
Are you getting fuel and spark?
Old 06-25-2011, 12:54 PM
snrusnak's Avatar
Rep:1385
Check that a plug didn't come loose, happened to my s10, I did a tune up and a month later it would sputter and it was a plug that backed out. Again, start easy, check spark, then compression, then fuel...
Sean
Old 06-27-2011, 03:17 AM
cherry98 cherry98 is offline
Vehicle: 1998 Ram 1500 ext Cab
Trim Level: SLT LARAMIE
Color: silver pearl
cherry98 is on a distinguished road
i had the same issue with my supercharged foxbody i would crank but not start i checked everything and a month later i found out that the fuel filter was clogged i changed it out cycled the key and it fired up and i was back to having fun
stock (for now) silver 98 1500 4x4
stock (for now) white 06 1500 mega cab 2wd
Old 06-29-2011, 12:38 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
See if your CPS is up to par, the CPS are known to fail.
Old 06-30-2011, 02:39 PM
countryboy85's Avatar
countryboy85 countryboy85 is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Trim Level: SLT Big Horn
Rep:16
countryboy85 is on a distinguished road
I'm having the same problem with my '99 1500 right now. I had a bad fuel pump, and replaced that then only to find that I was not getting any spark. I'm replacing the distributor cap, rotor, plugs, and wires tonight. If it is your fuel pump, and you decide to install it yourself, good luck. It was a pain in the butt to pull the tank to get to the pump. I did save over $300 by doing it myself though.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 10:14 PM
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 09:48 PM
Truck won't start !!!!!! help! jjvross 4.7L PowerTech V8 Specific Topics 2 04-05-2011 10:38 AM
My new truck won't start again! rich1500 2010 Dodge Ram Forum 10 09-21-2010 01:28 AM
