Truck will crank but won't start - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-30-2011, 01:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
As far as the fuel pump.....on my s10 I found it easier/faster to remove the bed to access the pump. Not sure if this would be the same with the ram. I would disconnect the tail light harness, remove tail gate, disconnect 3 bolts for fuel filler hose, then 6 bolts underneath holding the bed on, and a few neighbors (tempted with a six pack) and then you can work standing up (or sitting on the frame). Much easier IMO. Probably would take you an hour to get the bed off...
Sean
Old 07-01-2011, 09:51 AM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
Originally Posted by countryboy85 View Post
I'm having the same problem with my '99 1500 right now. I had a bad fuel pump, and replaced that then only to find that I was not getting any spark. I'm replacing the distributor cap, rotor, plugs, and wires tonight. If it is your fuel pump, and you decide to install it yourself, good luck. It was a pain in the butt to pull the tank to get to the pump. I did save over $300 by doing it myself though.
I found it easier to just unbolt the bed and lift it up on one side.
Old 07-05-2011, 09:42 AM
countryboy85's Avatar
countryboy85 countryboy85 is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Trim Level: SLT Big Horn
Rep:16
countryboy85 is on a distinguished road
ok. I know that this is someone else's thread, but I'm at a dead end with the same problem. here's the situation with my 1500:
first off, i do not have a check engine light. one day while slowing to a stop at a light, the truck died and would not start. i checked the fule pump, and saw that it went bad, so i replaced it. tried to start and i found that i was not getting any spark. replaced the plugs, wires, distributor cap, and rotor since i'm sitting at 160,000 miles. i replaced the ignition coil and now have a good spark (found that out the hard way ), but still not starting. someone told me to check the crankshaft sensor to see if that's bad, but after that i have no clue what to do next. can anyone out here help?
Old 07-06-2011, 08:19 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Did you replace the CPS?
Old 07-10-2011, 04:48 PM
DougDoug DougDoug is offline
Vehicle: 1999 Dodge Ram 2500 4x4
DougDoug is on a distinguished road
I'm happy to say the truck is finally running great. The problem was a clogged catalytic converter. Completely removed everything inside of it, so it's really just like straight pipes but looks like a functioning catalytic converter, and it runs great! Thanks for everyones input.
Old 07-10-2011, 05:52 PM
snrusnak's Avatar
Rep:1388
Was there no check engine light on? That's very strange.
Sean
Old 07-12-2011, 10:54 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
yeaaaa thats a liiiittle sketchy...
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 07-12-2011, 10:57 PM
snrusnak's Avatar
Rep:1388
...not to pass judgement, but I think he may not check this forum anymore lol, judging by his 3 posts and no response to my question...
Sean
Truck won't start !!!!!! help! jjvross 4.7L PowerTech V8 Specific Topics 4 10-22-2017 09:57 AM
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 09:14 PM
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 08:48 PM
My new truck won't start again! rich1500 2010 Dodge Ram Forum 10 09-21-2010 12:28 AM
