Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-25-2011, 07:07 AM
krh9848 krh9848 is offline
Vehicle: 2011 Ram 3500
Trim Level: Laramie Longhorn
Color: Pearl Black and Tan
Rep:23
krh9848 is on a distinguished road
Default Axle questions and build sheet codes
I'm a newbie to Dodge trucks and have a question about the axles that are used on the 2011 Ram 3500 4X4 dually. My build sheet says the following:
  • DJES 5,500# Front axle w/Hub Ext - What is the Hub Ext? it doesn't have manual hubs
  • DMES 3.73 Rear Axle Ratio
  • DSAS Anti-Spin Differential Rear Axle - Who makes this axle Dana?
  • DS7S Convential Diffential Frt Axle - Same question who makes it?
Are there any info sheets out there that explain these build sheet codes?
Thanks in advance for the help
Old 06-25-2011, 06:40 PM
Rep:2657
look at the differentials
there Should still be paper stickers on both of them
those stickers will tell you what you have
take a picture of them or write everything down, because they won't stay on there long
Old 06-26-2011, 08:22 AM
Rep:23
Thanks, I was going to crawl under there and look but it was raining when I posted lol. I did some more web digging and found replacement diff covers that say the the axles are AAM (American Axles Manufacturing - I think). The front appears to be 9.25 if the replacement cover I was looking at was correct and the rear is 11.5 14 bolt of the same make (AAM). It appears that these are the same axles used by GM in the duramax.
I would still like to know if there is some sort of decoder ring for the build sheets
Thanks
318 build questions charlson 5.2L V8 Specific Topics 1 06-01-2010 10:10 PM
