Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-25-2011, 05:02 PM
tomstruck tomstruck is offline
Vehicle: 2005 dodge ram
Color: Blue
tomstruck is on a distinguished road
Default 05 ram blows hot air only
HI IM NEW AND TRYING TO LEARN MY WAY AROUND. SO THE PROBLEM IS I CHECKED THE ACTUATOR MOTOR AND ALL THE NORMAL BLEND DOOR PROBLEMS ALL SEEM OK. I REPLACED THE MOTOR BUT I GET NO MOVEMENT FROM THE BLEND DOOR ACTUATOR. COULD IT BE THE CONTROL PANEL ON THE DASH?? EVERYTHING ELSE WORKS FINE JUST NOTHING BUT HOT AIR EVEN WITH THE AC ON. HELP PLEASE I CANT AFFORD TO KEEP REPLACING THINGS I DONT NEED BUT CANT AFFORD TO PAY TO HAVE IT FIXED EITHER.
Old 06-25-2011, 05:03 PM
The only thing I can think of is your system has a leak and you have no refrigerant left. One way to be sure is to have the system pressure tested.
Old 06-25-2011, 08:01 PM
Rep:2657
don't they make a colored dye that you put in the a/c valve to find leaks?
Old 06-26-2011, 12:03 PM
Color: Blue
Thanks for the thought but I mean hot air the control does nothing at all. The actuator motor does mot move the blend door's it is in the hot position no mater where i turn the heat control. I went to heatertreater.net and performed the diagnostics they recommend so i know it's not the usual broken blend door. ???
2001 Ram 2500 A/C - sometimes blows hot - sometimes cold hammerheadn Heating & Cooling 1 06-14-2011 06:19 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
2001 Dodge Ram Air Conditioning westbygodtbone Heating & Cooling 1 05-03-2011 10:18 PM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
AC blows humid air Adub 2009 Dodge Ram Forum 4 03-28-2011 02:37 PM
