Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 06-25-2011, 06:34 PM
Drkangel1's Avatar
Drkangel1 Drkangel1 is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Drkangel1 is on a distinguished road
Default Rear End Oil Change
Ok maybe some can help me here I want to change the differential oil in the rear so I went to Kragen auto part store and ask for the gear oil and LSD oil for my 2010 Dodge Ram 1500 4x2 and he showed me 4 to 5 different brands and wights and one type 4oz LSD oil some where synthetic and regular gear oil. My question is what brand / weight gear oil to use, synthetic or regular and how many bottles does it take and how often does it need to be changed . any help would be great. Thank you
Old 06-25-2011, 07:53 PM
Rep:2616
your rear end only uses SYNTHETIC fluid
You need to look at your owners manual for types & capacities
i believe that only 4X4 & 2x4 with Limited Slip Differential use LSD fluid
as far as Kragen/Oreilly goes, their people were either in high school within the last year or 2 & always ride a bicycle or a skateboard
They probably couldn't show you where your dipstick was located
Next time you should go to NAPA, at least they only use the computer to double check part numbers
Old 06-25-2011, 10:59 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
For rear ends the oil used can be either synthetic, conventional, or blend. He would be using a hypoid gear oil which most are because they are backwards compatible so it would just make sense to make just hypoid. Anyways because you have a LSD you need a Posi-Trac additive. You can go to the local autozone and get Trans-X Posi-Trac Additive, it's sold usually by the tube, it's an additive for the LSD clutch's etc. Anyway's the weight depends on the temperture that the truck will most likely operate in and what kind of use for the truck. If you do alot of towing I think you would use 75-140, I use 80-90 because I can use it in both high and low temp environments, but their is some restrictions such as if I do towing but the oil will still do it's job just might get a little bit hotter. Anyways if you look in the owners manual their will be a chart with weights and temps along with oil weights that would be best for using in a towing environment. I changed my differential fluid and just used 2 Bottles of Valvoline 80-90 and a tube of additive even though I don't have a LSD. The additive isn't going to do any harm in a differential without LSD, BUT IT IS NEEDED IF YOU HAVE A LSD. Anyways, the manufacture uses RTV for the axle housing gasket, but I used a felpro gasket and I put RTV on both sides of the gasket. I didn't fully trust using RTV or using just a paper gasket so I did both and it might prove to have been smart when I do my next gear oil change because the paper gasket will help with removing more RTV then just trying to scrape it etc... I have the chrysler 9.25 axle with a 3.55 ratio (typical)... Anyways when you put the cover back on torque the bolts to 30 Ft/Lbs once the sealant is dried. Well really just put the cover on with the sealant etc then finger tighten the bolt to the RTV seeps out of the sides of the cover and axle, then wait about 1-2 hours and then fully tighten the bolts to 30FT/LBS and then you can put gear oil in, BE SURE TO PUT THE ADDITIVE IN FIRST!
Part of this reply is for the person who posted this thread.
Excuse any grammer mistakes etc, I can't see very well and I am a little under the weather so bare with me here. Thanks
Old 06-26-2011, 05:42 AM
Drkangel1's Avatar
I want to thank GTyankee and Ramvan2500 for taking your time to reply to my post, all your information and input will be of great help agin thank you.
Old 06-26-2011, 12:47 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
If you tow be sure to use 75-140w. ( my stock gear lube got cooked towing 7500lbs). I always use a brand named synthetic like Royal Purple, or Valvoline so no LS additive is needed.
You may want to research on adding too much limited slip additive to a LSD as it can cause the clutches to slip too much (stop working).
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 06-26-2011, 02:42 PM
ramvan2500's Avatar
Rep:128
An additive is still recommended because the additive is a friction modifier much like ATF is a friction modifier, the LSD consist of clutches much like a transmission consist of friction plates and steels that are made to be known as clutch packs. So the additive is a good idea, and yea that stock oil I'm sure cooked very good, valvoline is all I use and nothing else. Great Stuff!
Anyways yes like I told him 75-140 would be best for towing, but their are others that can be used, it just sucks though when you have to keep changing gear oils left and right... But you got to take care of the truck you want it to keep running
Old 06-26-2011, 02:43 PM
ramvan2500's Avatar
Rep:128
You're very welcome and I know I am more than happy to help you with anything in the world with your truck, just knock on my door and help is on the way.
Old 06-26-2011, 04:57 PM
Drkangel1's Avatar
Agin Ramvan2500 thank you agin for all your help and too every one else for there input this fourm is one of the best.
Old 06-26-2011, 05:42 PM
Rep:2616
DRKANGEL
this is from the 2010 Ram Owners Manual
Page 555 Fluid types
Rear Axle – 1500 Models MOPAR Synthetic Gear Lubricant SAE 75W-140 (MS-8985).
it does NOT read it but equivalent fluid is acceptable
Limited-Slip
Rear Axles require the addition of 118 ml (4 oz.) MOPAR Limited Slip
Additive or equivalent.
Old 06-26-2011, 07:22 PM
Drkangel1's Avatar
Thank you GTyankee
Cost to change rear gear ratio. TJB10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 22 06-26-2013 12:19 AM
Oil Change Indicator highlandchef Oil Change 12 06-16-2011 06:11 PM
Rear End SHOT! BOSS 32V 5.7L V8 Specific Topics 3 03-25-2011 04:20 AM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 02:00 AM
Rear end fluid change stangguy1 Oil Change 17 01-02-2010 12:09 AM
