Old 06-25-2011, 07:57 PM
Wolfpack Wolfpack is offline
Vehicle: 2011 Dodge Ram 4WD Outdoorsman
Trim Level: Outdoorsman 4WD
Wolfpack is on a distinguished road
Default 2011 Recall K36 Experience (Rear Axle)
I got a call from the dealership this week saying I needed to bring in my 2011 RAM 1500 (Outdoorsman 4x4 Crew Cab) for an important safety recall. Apparently, the rear axle pinion bearing may not get enough lubrication because the fill port was designed too low on the rear end / pumpkin. The recall includes replacing the back cover of the pumpkin and putting a flow restrictor to make sure the lubrication is appropriate.
I insisted on seeing the gears when it was open and had a good talk with a very knowledgeable technician. He said mine looked fine and that it probably had received additional lubricant before I took it off the lot in April. When I checked out, I noticed in my service history that the dealership had done this.
If you get that recall notice, get an appt ASAP. Apparently this lack of lubrication can result in the rear end overheating or even locking up. My truck had 3,100 miles and there were no metal filings in the pan or any evidence of premature wear. I feel a lot better after talking to the tech and I'm really glad I have a 75k mile comprehensive warranty...
Attached is a photo of the rear end with the gears exposed.
Old 06-25-2011, 08:08 PM
Rep:2657
did you happen to see what the flow restrictor looked like, i have been curious about it, i have seen images of the cover plate
Old 06-25-2011, 08:31 PM
It's a thin piece of sheet metal with a few bends. I bet that's less important than the additional fluid that is needed in the rear end. I should have taken a photo - maybe if there are any Dodge techs, they could post a photo?
Old 06-25-2011, 09:00 PM
Glad ya got by with no damage!
Old 06-25-2011, 11:01 PM
Amen brother - had trouble sleeping last night!
Old 06-25-2011, 11:37 PM
leardc's Avatar
leardc leardc is offline
Vehicle: 2011 Dodge Ram 1500 Crew
leardc is on a distinguished road
Is this ALL vehicles? I don't have the Outdoorsman, and haven't heard anything about a recall.
Old 06-26-2011, 12:30 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Look in this thread http://www.ramforumz.com/showthread.php?t=78910 there is a link on the first page enter your VIN number to find out if you are in the recall list, hope this will help.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 06-26-2011, 01:14 AM
leardc's Avatar
Says database unavailable right now. I guess I'll try tomorrow. Thanks for the link
Old 06-26-2011, 10:23 AM
joewally joewally is offline
joewally is on a distinguished road
mine goes in tomorrow morning to get the recall fixed
Old 06-26-2011, 01:33 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
There are no recalls in effect for your vehicle.
VR_104--No Incomplete Recall Exists
I guess my truck is ok.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
2011 R/T Rear Diff Cover militarymopar 2011 Dodge Ram Forum 10 01-16-2013 02:31 PM
Rear Axle Recall? ramrt1993 Dodge Ram R/T 24 05-14-2011 05:16 PM
anti-spin differential rear axle Andy37 Newbie Checkin! 6 06-14-2009 03:17 PM
rear axle swap satcombinky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 05-30-2009 10:45 PM
What size socket for rear axle? rfishman47 Suspension 0 05-28-2009 12:32 AM
