Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 06-26-2011, 01:13 AM
Rammy03's Avatar
Rammy03 Rammy03 is offline
Vehicle: 2003 Dodge Ram
Color: Tan
Rammy03 is on a distinguished road
Default Front Suspension POP!
Ok, so I'm about to lose my damn mind on this . I have a loud popping noise on the front end when I brake and take-off. I have replaced everything I could possibly think of, here's a breakdown list. Lower ball joints by Moog, Upper control arm and ball joint, sway bar links, outer tie rods, spindles, springs, lower control arm bushings, All polyurethane bushings to include sway bar, alignment and balancing. So pretty much the only thing I haven't replaced lately is the shocks, Any help would be appreciated.
Thanks Guys
Old 06-27-2011, 11:58 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-20-2011, 06:31 PM
MlMcMonagle MlMcMonagle is offline
Vehicle: 2005 Dodge Ram 1500
Color: Charcoal
MlMcMonagle is on a distinguished road
It could be anything could it not? You say when you brake, what do you mean? Repetitious as in continuing when you brake? It's a short pop? Um.. idler arm/pitman arm, or is that the sway bar links? I dunno I just got my ram and have some popping noise also, I think it's the bushings on mine. Used to have an s10 I needed to get em done. Anywho, you're probably more experienced than me but just trying to throw options your way. Good luck!
Old 12-24-2011, 02:22 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
did you loose a anti rattle clip that snaps into the caliper to hold the pads in place cause that what it sounds like.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 03:32 PM
Squeaking front suspension, turning and bumps Lockard191 Suspension 3 03-25-2011 07:04 PM
2007 Big Horn front suspension dee Suspension 1 06-03-2010 05:13 PM
Front Suspension TerryXn9 Dodge Ram General Discussion 3 02-09-2010 01:36 AM
