Cam choices - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-03-2011, 05:59 PM
heavy2500's Avatar
heavy2500 heavy2500 is offline
Vehicle: 2003 Ram 2500/ 2005 Ram 3500
Color: grey
heavy2500 is on a distinguished road
Default Cam choices
Im looking for input from the guys with cams, I've got an 03 2500 with 7inch lift an 37 inch tires, So Im not looking to win any races with the truck but gain big numbers on the low to mid range to help get the truck moving and improve the mpg numbers. thanks for any input.
Old 07-03-2011, 06:15 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
what gears are you runnin?
Old 07-03-2011, 06:25 PM
heavy2500's Avatar
Color: grey
I have the stock 3:73
Old 07-03-2011, 07:05 PM
CHVYKLR's Avatar
Rep:252
it'll run you a couple of hunderd bucks more but I think some 4.56 gears would serve you better to get those 37" meats a turnin.
for the money I just don't think you'd be happy with the gains you'll see from a low end cam.
Old 07-03-2011, 07:12 PM
heavy2500's Avatar
Color: grey
yea I would love to get the gears right now but the wife gave me a cap of $500 bucks right now an ive got all the 6.1 springs an push rods plus timing set for a cam swap.
Old 07-03-2011, 07:51 PM
marshallsmith44 marshallsmith44 is offline
Vehicle: 2007 dodge ram 1500
Rep:74
marshallsmith44 will become famous soon enough
4.56s would make your truck feel twice as powerfull, not sure on which cam you should go with but would you be installing it or having it done by someone?
Old 07-03-2011, 08:39 PM
heavy2500's Avatar
Color: grey
I would install it
Old 07-03-2011, 09:53 PM
CHVYKLR's Avatar
Rep:252
hopefully some of the gen III guys will chime in. in the mean time you can check out comp cams website. it has an interactive program where you plug in your truck/motor info and what you want to accomplish then it spits out a recommendation. I guess I would also give Stu a call at Inertia Motorsports also.
don't forget about getting the cam dyno tuned.
Old 07-03-2011, 10:13 PM
heavy2500's Avatar
Color: grey
yea i got with stu on my srt max for the magnum an I didnt know comp had that Ill go check it out.
Old 07-03-2011, 10:33 PM
heavy2500's Avatar
Color: grey
Yea the comp 260 is looking like its in the rpm range i drive the truck i found a few under $350 seems like a good choice but if anyone has diffrent op im open for input
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 12:30 PM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
