Old 06-26-2011, 05:51 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Nervous about making the muffler switch
I have a Flowmaster 40 Series and love the sound, but from what i understand if i switch to MagnaFlow ill see a difference in power. What kind of difference should i expect? I hear about cherry bomb extreme, hows the flow compared to magnaflow? And hows WOT? Is MagnaFlow about the best for our trucks?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 06-27-2011, 06:11 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Not sure about the cherry bomb extreme, but I can see right through my Magnaflow..."flowmaster" not so much! And my full stainless steel mag will last as long as my truck does!
Here are the Cherry Bomb cutaway pics
http://www.google.com/search?rlz=1T4...w=1600&bih=744
Old 06-27-2011, 06:20 PM
Rep:2616
I really don't believe you will notice a horse power or torque difference be those 2 mufflers, unless you are running at the drag strip with timing lights
just a sound difference, if you like loud exhaust get a shorter muffler, like a 14" Magnaflow
Old 06-27-2011, 06:50 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Well I have the flowmaster 40 and although the power feels about the same as stock (can't really tell the difference with my dyno butt ), I did notice a definite increase in MPG after having it installed. Increased MPG usually means better performance. Also the sound is amazing and that's not just me saying it as I get alot of compliments. Had it on for almost two months now and very happy with it.
Old 06-28-2011, 10:36 AM
sporty11's Avatar
sporty11 sporty11 is offline
Vehicle: 11 Sport
Trim Level: sport
Rep:23
sporty11 is on a distinguished road
just installed a 14" magnaflow on my '11 hemi, and when the shop pulled off the stocker they compared them on a bench test for the flow rate..
to the surprise of myself and the tech the magnaflow flowed only 10-15 cfm more than the restrictive stocker..
Stock = 1190 cfm
14" Magnaflow = 1205 cfm
As for performance i dont think much.. MPG, havent noticed a huge difference avg 17.1 mpg (calc by hand)
i like the magnaflow but if u looking for performance just a muffler swap isnt gonna give u much imo
cheers!
Bilstein 5100's, 1.25" RCX BL, Toyo ATll 35x12.5, 20" Fuel Throttle 0 Offset, 10" L3's, 2500w Mono amp, AFE Stage 2 Intake, 180 deg, 14" Magnaflow, Stage 2 Jet Performance Module
Old 06-28-2011, 11:52 AM
The Magnaflow has been my choice on cars and trucks for a while after having Flowmasters rust out on me.
However, the sound of an exhaust is a pretty personal choice. What sounds good to me may not sound good to you. In any event, I like the sound of the Magnaflow systems.
Performance gains depend on so many variables (temp, humidity, truck condition, other mods, etc...) that you can't just say it will get you a gazillion HP when you put it on and have that verified.
One thing to consider is that the internal combustion engine is just a big air pump...more air in + more air out = more power. So it's not just the muffler that makes a big change, it's intake, exhaust and programming that are the best bang for the buck mods when it comes to improving performance and, believe it or not, MPG.
So good luck with your mods!
Old 06-28-2011, 12:04 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
1190cfm stock? Geez
Stock = 1190 cfm
cheers!
Old 06-28-2011, 08:44 PM
RamOwner RamOwner is offline
Vehicle: 2010
Color: Mineral Gray
RamOwner is on a distinguished road
Like some earlier comments, I doubt you'll notice any real performance boost simply by replacing your muffler.
Old 06-29-2011, 01:08 AM
chefred112's Avatar
Rep:656
but it's a piece of a bigger puzzle...it performs better the more mods you add..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 06-29-2011, 07:35 AM
Color: RED<----
Rep:15
Stock = 1190 cfm
cheers!
If that's true maybe thats why the Flowmaster slows you down, cuz if i remember correctly Flowmasters dont flow as high as that
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
check guages light on DODGEARCHER Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 06-22-2011 11:21 PM
FINALLY Making the Switch to Synthetic jcasey10 Oil Change 19 02-26-2011 08:54 PM
Drivers door lock switch......... bigdaddyII Electrical 9 01-25-2011 12:09 PM
Magnaflow and Borla Muffler Fury 2010 Dodge Ram Forum 6 03-24-2010 09:27 PM
