Dodge Ram Decals
Old 06-26-2011, 10:37 PM
MonsterRamAlaska's Avatar
MonsterRamAlaska MonsterRamAlaska is offline
Vehicle: 1998 Dodge Ram
Trim Level: Quad Cab
Color: Electric Blue
Rep:24
MonsterRamAlaska is on a distinguished road
Default Cylinder 5 misfire for 98 ram
Hey, so here is where I am at.. My truck has had the check engine light on since I bought her. I checked the code with a computer and it said cylinder 5 was misfiring. So I got new distributer cap and new plugs and wires, also my compresion test was fine. I cleared the code and kept driving it. I checked it a while later and it said the same thing.. My friend suggested it might be the fuel injector is bad for 5, but I dont have fuel injectors if im correct, isnt there only one that distributes the fuel to all pistons? So Im not sure what it is
Old 06-27-2011, 01:57 AM
cherry98 cherry98 is offline
Vehicle: 1998 Ram 1500 ext Cab
Trim Level: SLT LARAMIE
Color: silver pearl
cherry98 is on a distinguished road
not sure about whats wrong with your truck but there is one injector for every cylinder i hope this helps a little
stock (for now) silver 98 1500 4x4
stock (for now) white 06 1500 mega cab 2wd
Old 06-27-2011, 09:09 PM
Rep:24
I was reading around this forum and came across other people having the same problem. Some people were saying it was induction or something from the wires from the distibuter to the spark plugs crossing and stuff. could that simply be enough to make cylinder 5 misfire?
Old 07-01-2011, 07:00 AM
shak01 shak01 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Emerald Green
shak01 is on a distinguished road
TSB:18-48-98
Symptoms: various single cylinder misfire (1, 3, 7,) ad especially 5 and/or 8
NOTE: This rerouting procedure should be performed before any other misfire, surge, or spark knock repairs are attempted.
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Kevin Sharpe shak@att.net
Old 07-03-2011, 06:20 PM
dafichter dafichter is offline
Vehicle: 1999 Ram
dafichter is on a distinguished road
I have a 99 that is doing the same thing, ran 3 different types of injector clearner threw it and has not helped. Thought about new plugs and wires.
Old 07-03-2011, 06:26 PM
Vehicle: 1999 Ram
Looked at the rerouting, could I just put sheilded plug wires in and would that fix the problem, I am not even sure that they make sheilded wires
Old 07-05-2011, 01:36 AM
Rep:24
I did a little rerouting on my wires, but I didn't see any significant changes. If there were shielding covers for the wires, that would be a lot easier than rerouting the rest of the wires..
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Cylinder 8 Misfire jono 2010 Dodge Ram Forum 4 05-06-2014 08:13 PM
Ticking, clogged CAT, cylinder misfire...all connected? FireItUp 5.9L V8 Specific Topics 1 06-13-2011 09:50 PM
Cylinder 5 misfire, and now cylinder 8 and a random misfire... suggestions? itsaRAMthing 5.9L V8 Specific Topics 5 06-05-2011 07:35 AM
Cylinder Misfire? GoTigers11 5.2L V8 Specific Topics 6 01-06-2011 04:22 PM
