Old 06-27-2011, 03:13 AM
BradZ's Avatar
BradZ BradZ is offline
Vehicle: 2011 Dodge Ram QC
Rep:23
BradZ is on a distinguished road
Default new truck audio upgrade question
Sounds ok, but I've always had aftermarket stereos in my cars. I want to keep the fancy u connect touch screen deck in my truck but replace the speakers (that's easy) and i need a sub. Crutchfield is always my go to but htey have no boxes for rams.
I need something for 2011 that'll fit under the seat, a single 10 should do the trick for base but I can't find any boxes. I do recall however when I was looking for info on these trucks seem to remember seeing a small box built for under the rear pass seat, for some reason I'm thinking Kicker but I could be wrong. Anybody know that or a similiar design
also, the package I didn't get had the center of the dash speaker in it, considering trying to add something similar, anybody know what's comparable with that?
Old 06-27-2011, 06:22 AM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
I am assuming you have a crew cab, non mega cab. You have several options available. JL audio makes several Stealth boxes that come preloaded with 1 or 2 subs depending on the application.
If you want add your own sub(s) you can find prefab boxes from:
Super Crew Sounds
Pandora Subwoofer box
Sub Thump
you can even find some on ebay.
I know there are a lot of other companies out there but I am drawing a blank. I am pretty sure anything marked at 2010 will work for a 2011. Can someone here validate that?
I can only speak for the JL Stealth boxes. I had one mounted in my center counsel in my 2004 F350. I plan on installing one into my Mega Cab when I get home for R&R. I have always been a fan of JL products.
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 06-27-2011, 12:47 PM
The dash speakers are 3.5" and you can reasonably fit a 4" in there with some dremel work.
What I have found is that music sucked with a center channel speaker as it sounded really muddy, not well defined, and I had some good speakers. Having some clear balance from side to side sounded a lot better.
Old 06-27-2011, 01:09 PM
cwking25 cwking25 is offline
cwking25 is on a distinguished road
heres a good one that might help http://caraudiofactory.com/2010-dodg...ted-p-419.html
Old 06-27-2011, 11:51 PM
BradZ's Avatar
Rep:23
thanks very much for all the links.
Old 06-29-2011, 03:35 AM
BradZ's Avatar
Rep:23
so after some browsing, does anybody know of a single sub box that doesn't require the removal of the fold out seat storage or at least won't require spacing modifications to the seats?
I've seen a picture of what I believe was the factory one that fit right inside left the fold outs as is, but if that's not possible I at least don't want to have to be adding spacers to my seats.
Old 06-30-2011, 08:35 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Here is a link to a sub box that should fit under the seat on the passenger side..
http://www.supercrewsound.com/commer...Id=67&catId=53
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 07-02-2011, 02:43 PM
11bigred's Avatar
11bigred 11bigred is offline
Vehicle: 2011 ram 1500 sport
Trim Level: Sport crew cab
Color: Flame red
11bigred is on a distinguished road
Mtx makes a box also,or just have one made at an audio shop,sometimes its cheaper depending on what you want made.
Old 07-02-2011, 03:00 PM
Yeah, check out MTX/Thunderform boxes. SuperCrewSound (the link above) carries those as well.
Old 08-16-2011, 11:10 PM
stravs stravs is offline
Vehicle: 2015 RAM 1500 CREW HEMI SPORT
Trim Level: SPORT
Color: MAXIMUM STEEL METALLIC
stravs is on a distinguished road
Default Quad/Crew Sub Box
I found this one before snagging a JL stealthbox off craigslist for $200 Looks like they offer a 10" or 12" option.
http://www.foxacoustics.com/ProductD...Code=DQC-112-S
question on audio upgrade Richie Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 10-21-2010 02:20 AM
audio upgrade. need help... armyrgr Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 09-17-2010 02:31 PM
Question about 1500 Brake upgrade... hemijames Dodge Ram General Discussion 4 08-31-2010 10:43 AM
Brake upgrade question? please help hemijames Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-23-2010 08:33 AM
Question about my new truck jhnnychimpo Dodge Ram General Discussion 16 01-06-2010 06:47 PM
