Air Lift 1000 Road Report - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 06-27-2011, 10:10 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Default Air Lift 1000 Road Report
So I installed these last week for a trip to the lake this weekend pulling the boat. Trailer isn't all that heavy, just over 3K, but we had 450 pounds of passengers, plus a few hundred pounds of gear in the bed, so I thought they would be a good idea. Round trip was about 350 miles to Truman lake in MO, so there were some pretty good hills and windy twisty roads.
Empty, I leave the bags at about 10 PSI, which makes for a nice ride, just a little firmer than stock, but it recovers from bumps better than stock.
Loaded, with a payload just over 1K with the trailer tongue weight, I set the bags at 20 pounds. Truck sagged maybe just over an inch. Ride was great. Boat is light enough that it wants to bounce over some bumps in the road, but the air bags really tamed that down, and aside from gas mileage, and the occasional wind gust, I pretty much didn't even notice towing the trailer.
For the towing that I have done (just over 4K and less), I love this truck. Mileage with most trailers has been right around 15 mpg with average speeds of 65 mph. Tranny never got over 168, and it was 95 F yesterday on the way home. For the weights I am pulling, I can set the cruise, and most hills I pull without dropping down a gear, and I have the 3.55's.
Just thought I would share. Most people probably look at Timbren or the air bags for towing, and for a whole lot less money, I think the air lift 1000's do a great job. Can't comment on the timbrens, but I can't see them being worth the extra money. Only advantage to them, I think the install would have been much simpler.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-27-2011, 10:22 AM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Good review. Thanks
Old 06-27-2011, 10:34 AM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Thanks for sharing. I pull trailers all the time. Since I have had the Ram, I have not had to pull anything over 3000 pounds. I know the day is coming, so I am trying to decide if I should add the Air Lift or go with something else. Where did you route your lines and do you have any photos of your install?
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 06-27-2011, 11:21 AM
Wildcat's Avatar
Rep:166
I didn't take any pics, but I can get some tonight and post them. I routed them along the crossmember between the tires, and T'd it there. Then I ran it down the frame rail, along the hitch and through the bumper, just to the passenger side of the license plate.
I left the tires on, but I would suggest taking them off, because I think it would have made the install easier.
Old 06-27-2011, 11:24 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Rep:1443
I'm going to get a set after I lower my truck to help prevent bittoming out, even at stock weight, 5-8 psi in the bags should help some!
Old 06-27-2011, 11:37 AM
Wildcat's Avatar
Rep:166
I keep them at 10 PSI for everyday use, because I don't have a pressure gauge that goes any lower than that. You might want to talk to someone at Air Lift first. Since you are lowering the truck, I am not sure if they will counter that and lift it some due to the height of the air bags.
Old 06-27-2011, 11:56 AM
916Timmy's Avatar
Rep:1443
They have shorter bags for the drop kits!
Old 06-27-2011, 12:07 PM
Wildcat's Avatar
Rep:166
I did not know that. Then they should work perfect for you.
Old 06-27-2011, 02:59 PM
916Timmy's Avatar
Rep:1443
Yeah, saw another post about them! Thanks for the write up
Old 06-27-2011, 04:16 PM
Wildcat's Avatar
Rep:166
Thanks for the reps! I will get some pics up tonight or tomorrow.
Air Lift 100 Install on an '09 brokenwrench66 Dodge Ram Knowledge Base 14 04-05-2015 05:13 PM
Air Lift 1000 - Am I the only one? Upstater LD RAM - General Discussion 15 06-20-2011 09:28 PM
Air Lift 1000 install. bucmachine Suspension 30 06-17-2011 10:26 PM
Air Lift 1000 Install w Pics brokenwrench66 Suspension 1 06-15-2011 11:59 PM
What brand rear air bags (firestone or air lift) for towing upgrade? Bocephus660 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 06-09-2011 10:57 PM
