Old 06-27-2011, 08:35 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
Default Installed aFe Stage 2 Intake w/Pictures
I installed an aFe Stage 2 on my R/T tonight and I really like it! I paid $276 for it, it fits great, took about an hour to install, and it sounds great at WOT. One thing to note, on the hose to the crank case, a clamp wasn't included so I added my own, you can see it in my pictures.
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 06-27-2011, 11:34 PM
JLSFF07's Avatar
JLSFF07 JLSFF07 is offline
Trim Level: Big Horn 4x4
JLSFF07 is on a distinguished road
Looks good i ordered one as well, hope to get it soon. Thanks for the writeup
Old 06-27-2011, 11:46 PM
11bigred's Avatar
11bigred 11bigred is offline
Vehicle: 2011 ram 1500 sport
Trim Level: Sport crew cab
Color: Flame red
11bigred is on a distinguished road
Looks good.....not a bad price either
Old 06-28-2011, 02:21 AM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I'm running the same one, and I think it is well made and works fine, I clamped the hose onto the intake tube with a small hose clamp, just to make sure it stays put
So it is written ! So it shall be done!
Old 06-28-2011, 10:09 AM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
A few notes I'd like to add...I heard a rattling noise when I first started it up, but it was gone after 10 seconds and I've never heard it again. Also, a rubber sealant was included to seal the heat shield and the bottom of the OEM airbox. I did not install it for two reasons. 1, the filter is out in the open, what difference does it make if I seal it? 2, the heat shield was a bit difficult to snap on and the sealant would make it even more difficult.
I drove my truck around a lil and did some hard acceleration and I am in love with the engine noise! I dunno if it added any power to my truck though, but I think it did I'll be checking my EVIC for any MPG gains.
Old 06-28-2011, 10:48 AM
Very nice. I installed a Stage 1 on my Ram last year and really like it!
Old 06-28-2011, 11:30 AM
Rep:27
Ramrt,
I'm not sure what heat seal your talking about, are you refering to the rubber edge strip?
If so, it's purpose is not as a seal, it is used to put a finishing edge on the sharp top edges of the open air box.. Just makes a nice finished look and feel to the box, I would suggest installing it, pretty easy only tricky part is where it bends around the two corners, a little tap with a plastic or rubber hammer helps.. As to any rattles, shouldn't be any... Just check all around your install, and in your air box, any tools, or pieces, parts ????? Perhaps something dropped and is hidden under your filter???? I added a pre filter bag over my filter and a throttle body spacer also...I lost about 3 mpg overall, but it runs good and sounds good
Old 06-28-2011, 12:05 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
Yep, that's what I was talking about, I just couldn't come up with a better name for it. Mine sealed really nicely though without it, and its already a snug fit.
Now when I think of it, I may have dropped a little piece of metal when I cut a little piece of the extra hose clamp I put. It probably vibrated against something before falling down, creating that temporary rattling noise.
Losing 3 MPG would put me at 13.5 and I sure hope that doesn't happen and I don't think it will. I'm quite sure I'll get at least 1 MPG more!
Old 06-28-2011, 12:24 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
^^^ I would agree that a 3 mpg loss would have me ripping that thing off in a hurry.
It looks good, and apparently sounds even better. Nice install!
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-28-2011, 12:46 PM
LoneWolfNY's Avatar
LoneWolfNY LoneWolfNY is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
LoneWolfNY is on a distinguished road
Should I wait till my motor is broken in (only around 500 miles on her now) before I install mine. I read on here somewhere the motors are already running lean from the factory and adding the intake will only lean it out more. Shouldn't the computer notice I"m getting more air and richen the fuel up a little. Are should I just wait till the diablo becomes available?
Trinity, 180 Tstat, Magnaflow 18" muff no resonators, S&B CAI w/scoop, Bilstein 5100 Series Shocks all around, Billet Tech Oil Catch Can, AVS Vents, De-badged
afe stage 2, hemi 5.7, intake, k&n cai, volant
3.9/5.2/5.9 Intake Removal & Installation RamTech Dodge Ram Knowledge Base 6 08-28-2013 05:03 PM
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
Installed k&n cold intake and it rocks! dkettles Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 06-28-2011 12:21 AM
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 09:01 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
