Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 06-28-2011, 09:05 AM
jbaidas81 jbaidas81 is offline
Vehicle: 2000 Dodge Ram
jbaidas81 is on a distinguished road
Question Lift Kit Help
I'm wanting to put a lift kit on my 2000 Dodge Ram 1500 2x4 but I'm having issues locating a kit to run with. My mechanic (good friend of mine, ex-navy buddy, known for about 13 years) said that a suspension lift not only looks better but it also performs better and that I'd get more enjoyment out of it rather than going with a body lift. I'm looking for a 4 - 6 in lift for my truck; however, the only ones that I seem to find are for 4x4 trucks. Will a 4x4 suspension lift work on my 2x4 or not? Does any one know where to find a good 4 - 6 inch suspension lift kit for my truck that won't break the bank? Any help would be greatly appreciated, thanks in advanced.
Old 06-29-2011, 01:46 AM
texred's Avatar
texred texred is offline
Vehicle: 2000 dodge ram 1500
Trim Level: ram 1500 4x4
Color: red
texred is on a distinguished road
Fabtech. Or skyjacker. But they run 1000 n up but im running a 3in fabtech and adding a 3 body lift. Goodluck
Old 06-29-2011, 06:51 AM
i2c
Hi jbaidas81,
i got a 6" fabtech suspension lift kit for my 96 2wd. The only problem on my truck with the lift is the steering. my truck has independent front suspension and pitman and idler arm wear out fast, i am still working on a solution for that issue. Good Luck for your project!
Old 06-30-2011, 08:23 PM
rammer01's Avatar
rammer01 rammer01 is offline
Vehicle: 2001 dodge ram 1500
Trim Level: sport
Rep:14
rammer01 is on a distinguished road
im also looking for the same 4-6 inches of lift on my 2wd so ill tell you what im going to do to give you an option to think about. ebay has 3" lift spindles that replace your stock ones with no change in suspension geometry. on top of those im going to run a 2" spring spacer for a total of 5" up front, and then get blocks for the back. also, this way you can use your stock shocks for the time being if you dont want to shell out money for new ones. just keep in mind though if you do the spindles they require a 17" wheel for clearance.
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 07:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
Suspension lift vs body lift usmcoorah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 06-19-2009 01:13 AM
