Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-28-2011, 11:41 AM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
Default easily adjust shift points, without a tuner
i remembered reading something when i had my durango about adjusting shift points, and when the transmission shifts at what rpm's. i did a little research on it today, and found a prette good write up on it. i did it on my truck and it works pretty good. slightly harder 1-2nd shift, and shifts at a higher rpm at WOT. heres the link to the site.
i also found this, but havent done it yet, so im not sure on how itll work.
for the line pressure adjustment, drop the pan and look on the drivers side of trans towards the front for an allen head screw on a plate with a spring behind it. Turn it 1 1/2 turns CCW for firmer shifts. this adj. will only give firmer shifts and will not change the shift points. you will have to grind down a 3/16 allen wrench to fit because the head of the screw is kind of close to the side of the trans case.
File Type: pdf Dodge_Ram_Truck_Transmission_Adjustment.pdf (193.3 KB, 65 views)
Old 06-29-2011, 11:26 PM
Serrilion's Avatar
Serrilion Serrilion is offline
Vehicle: 2009 Lancer TURBO
Trim Level: ES Sport
Color: Graphite Gray
Serrilion is on a distinguished road
Send a message via AIM to Serrilion Send a message via MSN to Serrilion Send a message via Yahoo to Serrilion
Glad it is working out for you. I would only worrie because we all know the 46re and 48re are well... they've had there issues for awhile, so messing with there shift points, idk... But looks very tempting... always thought 2nd was too damn long in the autos
Old 06-30-2011, 09:34 AM
yea, it took some fine tuning on mine, but its working pretty good. i like it. i didnt adjust the line pressure, just adjusted the tv cable.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Which tuner for 2004 shift points? Quiet Lunatic 5.7L V8 Specific Topics 5 11-02-2013 09:09 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
shift points liljohn30 Diablo Predator Questions & Info! 2 09-06-2010 08:09 PM
Tuner to change shift points in an '04? HemiGTX Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 05-08-2010 10:30 AM
