Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 06-28-2011, 01:17 PM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Default Tow rating confusion
I have a Ram 1500 quad cab 4WD with the 8 foot bed and a 360 with 3.92 gears and the tow package. I am looking at renting a skidsteer and don't want to pay the extra $100 to have it delivered so I want to tow it myself. The skidsteer weighs 5808 lbs and the rental place doesn't have a weight for the trailer but I assume it's at least 2000 lbs. That would put me at 7808 lbs. I know the max tow rating for an 02 ram is 8400 lbs, but that's for a regular cab, short bed 2WD. So I looked on dodge's website to view my tow rating and it is only 6850 lbs...does the 4WD and extended cab and bed really affect tow rating that much? I am also confused because it shows the tow rating for the 3.55 axle ratio and 3.92 axle ratio and they are both the same?? So does this mean the extra money for the 3.92 ratio and tow package are worth nothing? That seems far fetched to me. Here is the link to the dodge page I went to for the tow rating so you can see for yourself: http://www.dodge.com/towing/D/vehicl...peed+Automatic
Any input or help is appreciated. Thanks in advance!
Old 06-28-2011, 01:34 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That doesn't seem right, I'd suggest looking up the "body builder" link that give the tow ratings...
Sean
Old 06-28-2011, 01:46 PM
Redlongbed's Avatar
What do you mean by the "bodybuilder" link?
Old 06-28-2011, 01:50 PM
snrusnak's Avatar
Rep:1385
Sorry It's a link here http://www.dodge.com/bodybuilder/year.pdf but I didn't realize it doesn't go back to your year. I think you have to download and save the file, then open it and you can click on your year, bed size, cab size, etc... if you try to do it in the internet explorer I don't think it let's you click the links.
Sean
Old 09-01-2011, 12:44 AM
tdub2112's Avatar
tdub2112 tdub2112 is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:16
tdub2112 is on a distinguished road
Your truck should have a label on the inside of the driver side door that gives specs and tow ratings.
My truck is almost the same, just a short box 96. It will tow 7600lbs. We had a 2000 lbs trailer loaded with our 02 Suburban on it and it pulled it okay. He definitly strained, but we made it. I wouldn't think that it would be a problem unless you're towing up some hills, then it might get interesting.
Old 09-01-2011, 02:47 AM
Rep:2705
engine size is a small part of the equation, bigger cubic inches the better
there is also the transmission, standards are better then automatics
the rear end ratio, the higher numerically ratios are best for towing, ( 3.91s are better than 3.55s )
the spring type, leaf springs are better than coil
the tire size, 17 inch tows more than 20 inch
the receiver hitch CLASS, class 4 is the best
the dodge sites don't consider many of these
Confused about tow rating Redlongbed Towing 1 06-27-2011 12:03 AM
Octane Rating (good info) Jay Fuel System 21 06-08-2011 02:02 AM
Axle manufacturers weight rating? WesGPS Dodge Ram General Discussion 0 10-04-2010 03:48 PM
Help needed for axle rating question please. WesGPS Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 09-23-2010 03:01 PM
Octane Rating (good info) Jay Dodge Ram General Discussion 3 03-27-2009 09:30 AM
