Old 06-28-2011, 02:19 PM
FFwhipple's Avatar
FFwhipple FFwhipple is offline
Vehicle: '04 white 1500 SLT QC 2WD
Rep:24
FFwhipple is on a distinguished road
Default 3" suspension lift questions and advise needed!
sooo i have a 2004 quad cab 4x2 that i want to give a better look to.. soo i want to lift it.. first i was just goint to do body but then i found this.....
http://www.roughcountry.com/dodge_2wd_02-05_3.html
it seems like a real good deal to me..
just a few questions...
-if anyone is running this could you post pics...
-its got the factory 20's on it now soooo... what am i going to have to look at for wheel and tires? best look for not much $ maybe...?
-can you do this yourself? my good friend is veryy mechanical savy and im not toooo bad myself...
-any other opinions or input is welcome!
thanks guys!!!
Firefighter-EMT-Student---"Find em hot,leave em wet"
MODS= 6" RC Lift, 951s, 35" Toyo M/Ts..
Old 06-28-2011, 05:53 PM
FFwhipple's Avatar
Rep:24
also not just doing it for looks or to be a "4x4 wannabe"
im a POC firefighter so for brush fires and what not it would be niice to have that extra clearence..
and to ansewer my own question about the wheels im pretty sure i can just put way bigger tires on these because i saw a guy on here with a 6" lift and i wanna say 37s on the factory 20s...
anyways.. thanks..
hope to hear some input soon..
doing a little moddin as we speak..
Old 06-30-2011, 01:10 PM
FFwhipple's Avatar
Rep:24
bumpy... may order soon
Old 06-30-2011, 04:40 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Hey welcome to the forums. Sorry I havn't replied till now.
I am not much on Rc lifts but that is a pretty good deal. Yes you can put it on yourself. You might beable to fit 35's under your truck. If not 33x12.50 if you get a negative offset wheel anyway. Hope this helps.
I have a 6" BDS +2.8" with 37's.
Old 06-30-2011, 04:47 PM
FFwhipple's Avatar
Rep:24
thanks for the info!
ill probley go with 33's, i just wish i could see that lift with 33's on a truck first not that would be ideal
Old 06-30-2011, 04:54 PM
Rep:463
Ya I understand kinda hard to judge the tire size without seing the truck lifted first.
Old 06-30-2011, 11:26 PM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
There are a few trucks on here with that RC kit 3" and easily clear 33s. They could probably fit 35s if they wanted to.
It's really hard to find pictures of that kit for some reason.
If you think about it stock 2wd 1500s can fit 33s with stock 20" wheels so by lifting the front 3" and the rear 1.5" it would leave plenty of clearance for 33s and could fit 35s with proper backspacing.
Old 07-01-2011, 11:57 AM
FFwhipple's Avatar
Rep:24
true..thanks for the input guys!!
i really wanna find someone with this lift because i would like to know if i will have to shim the upper control arms out in order to get the alignment correct...????
and to see how hard it could end up being to compress the new longer front springs for reassembley of the lower ball joints....???
well... if anyone knows this info lemme know! thanks!
if i do end up going with this kit, it will be in about a week.. so ive got a lil time to ponder it..
Old 07-01-2011, 03:16 PM
Rammin's Avatar
Rep:44
Never heard of alignment problems from that kit but I don't personally have one.
In order to put the springs in you will need a spring compressor. There are many inexpensive ones out there to buy (Harbor Freight) or you can rent one from your local auto parts store.
If you check on youtube there is a guy who shows exactly how to pull apart the front end to put in spacers above the coils. It's a pretty good step by step process and in 2 parts.
