Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 06-28-2011, 07:25 PM
NYR99's Avatar
NYR99 NYR99 is offline
Vehicle: 2016 Ram 1500
Trim Level: Sport 4X4
NYR99 is on a distinguished road
Originally Posted by caseykerner View Post
Look at this post i wrote last night. It explains the process.
OK. For the fogs, take the stock light out. Plug the stock harness into the raptor ballast. From the ballast, plug into the HID light and insert into the fog light housing.
For the lows, remove the grill/headlights (plenty of tutorials on the forums). Remove the rear plug on the headlight (this will require a hole drilled in it to route the wires through later). Find a good location to mount your ballast (I put mine on the frame rails with 3m body molding tape).Then remove the stock bulb and insert the HID bulb. Then, run the wire that connects to the stock low beam plug (located in the headlight housing) out to the bulb out warning eliminator (through the hole drilled in the headlight butt plug). From there connect the wire from the warning eliminator into the plug on the ballast. Then, run the wire from the output of the ballast into the HID bulb through the hole drilled in the headlight butt plug and replace the cover. Finally, plug the wires back into the stock wire harness (the two plugs outside the headlight with 3 wires on them) and set the headlight in its home.
You want to be sure to check for voltages on the fog lights to make sure you install correctly (ie. not reversed polarity) This is not too bad if it happens, (flickering/intermittent firing/ failure to light) just swap them around and you are ok. For the warning eliminators, you want to be sure you hook them up correctly or the internal capacitors will explode so think about everything before you energize the circuit. Once complete for both sides, test the headlights for any problems.
Hope this helps and is understandable. Any questions, just ask and I will try to help/reply as soon as I can.
KC
Thanks for the info but I think that's a litte too involved for me. I don't want to highjack this thread but can anyone recommend new bulbs that are just simply plug and play that will be better than the stock bulbs and look like the HID's?
Old 06-28-2011, 08:36 PM
caseykerner caseykerner is offline
Vehicle: 2011 Dodge Ram 1500
Rep:88
caseykerner will become famous soon enough
Silverstar ultra's are the closest you can get.
Old 06-28-2011, 10:29 PM
Ram2011sport's Avatar
Ram2011sport Ram2011sport is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew Cab
Color: Pearl Black
Rep:36
Ram2011sport is on a distinguished road
Hey "caseykerner" any luck with that tutorial showing how you put the LED's in the fake hood vents on your truck? I'm dying to get some ideas on how to mount them.
2011 Ram Sport CC! Mods:Mangnaflow Cat-back, Airaid, Jet180, HID'S, LED's EVERYWHERE!
Old 06-29-2011, 01:18 PM
ramrod2185 ramrod2185 is offline
Vehicle: 2011 Ram 1500
Trim Level: sport
Color: green
ramrod2185 is on a distinguished road
did you replace your headlamps if so with what?
Old 06-29-2011, 06:06 PM
Vehicle: 2011 Ram
Color: Pearl Black
Rep:36
Nope, headlamps are the same. Just changed the bulbs for the HID's
Old 06-29-2011, 08:31 PM
gjayf77 gjayf77 is offline
Vehicle: 2013 RAM 1500
gjayf77 is on a distinguished road
Truck looks awesome! love the headlights!
Old 07-02-2011, 09:34 PM
Vehicle: 2011 Ram
Color: Pearl Black
Rep:36
Got the intake and the exhaust on her today!
Went with the Magnaflow cat back, sounds awesome!
Also here are some pics of the LED set up I have, and the HID's in my headlamps and Fogs
Old 07-02-2011, 11:10 PM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
The bug has hit you hard, that is a good thing! Truck looks great...Don't stop.
RICHARD
14" Magnaflow,87mm TB, Vararam CAI,Diablo Trinity 91 Perf ,Edge 3000 Stall T/C, Tinted tail and 3rd brake light, rally stripes,Halo LED 55W HID projectors, LEDs inside and out, and many more options.
Old 07-02-2011, 11:41 PM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Looking Good
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 07-03-2011, 02:41 PM
shq's Avatar
shq shq is offline
Vehicle: 2011 RAM 1500
Trim Level: SPORT
Color: Grey
shq is on a distinguished road
Truck looks really nice, great mods. Any video of the exhaust sound?
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
Throttle body mod question! toddrod Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 32 02-17-2012 05:47 AM
5.2 first mod question? TRIPOD Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 5 06-30-2011 09:02 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
1st Mod gwidener350z 2010 Dodge Ram Forum 1 03-08-2011 09:34 PM
