Old 06-28-2011, 10:06 PM
vegas56 vegas56 is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: st
Color: blue
vegas56 is on a distinguished road
Default A/C Problems
I have a 2004 ram 1500 w/ the 5.7 hemi & 56k miles. The a/c has always been weak but now is getting worse.
It takes 2-5 miles to blow cold, will only blow warm when cruising at or over about 70 mph & blows warm under even moderate acceleration.
The freon pressures check out & I've already replaced 3 of the blend doors w/ aftermarket. All the dealer did was to check temps when parked in the shade & running @ 2000 rpm.
Other than the a/c I really like the truck but it's 110 here today & the a/c just isn't cutting it. Any help greatly appreciated.
thanks, Jerry.
Old 07-01-2011, 02:34 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-28-2011, 09:43 PM
Trim Level: st
Color: blue
Back to the top
Old 08-04-2011, 03:38 PM
cabnfevr's Avatar
cabnfevr cabnfevr is offline
Vehicle: 02' RAM 1500 SPORT
Color: blk
cabnfevr is on a distinguished road
Is your a/c coil fan working? It's located right in front of the coil.
Old 08-04-2011, 09:20 PM
Trim Level: st
Color: blue
Yes it is. Everything seems to work except that the compressor apparently shuts down.
Old 08-04-2011, 09:34 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Does low side pressure drop off when its running, if the compressor shuts off, its usually low on charge or you have a wiring issue, is there any dtc's. Pressures can still look okay, however the system can be low.
Old 08-06-2011, 02:03 PM
Trim Level: st
Color: blue
I don't know if the low side drops. When I checked the pressure a while back it seemed good but I didn't check it long enough for that. How can I check the wiring? Are there sensors that can be checked? Thanks.
Old 08-31-2011, 11:10 PM
Trim Level: st
Color: blue
The problem seems to have been dirty contacts on the sending unit on the refrig line. I took off the wires & blasted both sides of the contacts w/ electrical cleaner, let them dry & reinstalled. A/c now works better than it ever has. What a waste of 7+ years putting up w/ substandard a/c over dirty contacts.
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 12:32 PM
2005 Electrical Problems! 05Blackout Electrical 4 06-16-2013 09:23 PM
problems rainhater1 2010 Dodge Ram Forum 0 02-21-2011 09:45 PM
2005 engine problems and questions 05Blackout 4.7L PowerTech V8 Specific Topics 6 08-02-2010 11:16 PM
Hid Problems?? pcasso87 2009 Dodge Ram Forum 2 02-19-2010 07:05 PM
