if i add skyjacker leaf springs to lift truck what else do i need? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-29-2011, 07:37 PM
Chaz blue ram Chaz blue ram is offline
Vehicle: 2003 dodge ram 1500
Trim Level: st
Color: blue
Chaz blue ram is on a distinguished road
Default if i add skyjacker leaf springs to lift truck what else do i need?
My leaf springs are in really bad shape on my 2003 dodge ram 1500 so i'm thinking of adding skyjacker leaf springs to lift the truck since i have to replace the leaf springs anyways. what should i use to lift the front of the truck and do i need any other parts like long control arms or brake lines extenders, etc.
Old 06-29-2011, 10:15 PM
A level kit in the front will probably work. Depends on how much higher than stock the new leaf springs are. I suspect 2" but you need to find that out.
If this is all the lift you put on, then you won't need anything else such as longer brake lines, spliced electrical lines, longer control arms and the like.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Leaf springs zixxerluv Suspension 2 01-07-2017 04:17 PM
1998 Dodge Ram 1500 springs chaunceyb Newbie Checkin! 8 06-22-2011 05:36 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Tire size for truck with 3 inch lift Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-12-2009 07:10 PM
