Old 06-29-2011, 10:40 PM
Bent21606 Bent21606 is offline
Vehicle: 2011 dodge ram
Trim Level: Big horn
Color: grey
Rep:18
Bent21606 is on a distinguished road
Default getting ready for a long haul
ok so far i have towed alot with my ram. i have 3.55 gear in it fyi. i tow a 2000-2500 pound boat pretty much every weekend and thats 100 miles per trip. my dad used it to tow his 7-8000 pound boat bown the shore and i towed my camper once. the camper is about 3000 pounds and the last trip wasnt very far. this trip with the camper is to virginia beach and its about 6 hours. the camper does have electric brakes on it but i dont have the controller on my truck to use them, is it worth it for that light of a trailer? i guess i should just keep a eye on the trans temp?what is a good temp for towing? the only reason i ask is because my dad blew the tranny out of his 99 dodge with 80k miles on it towing a 6-7k boat from florida. any info or tips would be hepfull. i guess im going to just set the cruise on 65 put it in tow haul and go.
Old 06-29-2011, 10:47 PM
Keep it in tow haul mode and consider getting a brake controller in the future.
Can you check your trans temperature? If so, normal operating temp is 180 degrees. Of course, running down the road with no load it will be lower. Towing a heavy load, up a lot of hills, I would expect it to approach or exceed 200 degrees. This is not a dangerous temp but it would be prudent to take a break and let it cool a bit if it gets past 215.
Old 06-29-2011, 10:54 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
in some states its illegal to tow any type of trailer without electric brakes. If you have them on the trailer why not take advantage of them? plus it would take a load off the truck brakes.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 06-30-2011, 01:05 AM
gingrbredman's Avatar
gingrbredman gingrbredman is offline
Vehicle: 2011 Ram 1500 Crew Sport
Color: Deepwater Blue
Rep:89
gingrbredman will become famous soon enough
I would also agree the brake controller is something you should consider. For the 2011, you should be able to add the factory brake controller which plugs right in for less than $130. Not bad money spent imho.
Gusz 2011 RAM SPORT CC -Lockpick CHR550 -Hardwired Radar Detector - Custom Trailer Cam - -Fold a-Cover G4 - Bed Rug - Billet Shifter - Debadged - 18" Magnaflow - Custom Clear HID Projectors - LED Tailgate Bar - Custom Billet Badges -
Old 06-30-2011, 01:28 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I'd get a t/b controller. Consider it cheap ($125) insurance to what could go wrong.
I bought this one and installed it in the factory location. it comes with the correct harness too.
http://www.etrailer.com/Brake-Contro...sha/90885.html
Old 06-30-2011, 06:51 AM
Color: grey
Rep:18
hy wod go with a after marker one? do they have to be "flashed" not that i know what it is. and where can i order the factory one for 130? wouldnt that be better then after market? its a simple just plug it in?
Old 06-30-2011, 08:20 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Did it plug into the factory harness?
Old 06-30-2011, 11:29 AM
Rep:89
You can get the factory brake controller, and the bezel trim piece (depending on which color interior you have) from a couple different Mopar accessory stores. I ordered mine online from Mopar-wholesale cause other members here had good luck with them. My controller and bezel was around $130 delivered in a couple of days. Installation couldn't have taken more than 10 minutes.
Now I did not have mine "flashed" yet. This would allow the truck's EVIC system to recognize the brake controller and be part of the display in the dash. The controller works fine without the flash so you only need to do it if you want to see it as part of the EVIC. I almost look at it as how an aftermakrket one works. I can use a Prodigy to control my trailer brakes, but can't see it in the EVIC. The factory one just looks cleaner to me, and works great.
Old 06-30-2011, 11:54 AM
nikeman nikeman is offline
Rep:91
My truck came with the tow package and everything but how do you switch it to tow/haul mode? I have never seen this in my truck
Old 06-30-2011, 12:06 PM
CHVYKLR's Avatar
Rep:252
Plugged right in no problem.
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Long time member, long time Vacation. bigthignies Newbie Checkin! 17 01-29-2011 06:54 PM
In for the long haul delta Newbie Checkin! 11 12-03-2010 08:50 PM
Keeping it for the long haul rambuckeye88 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 1 02-28-2010 01:13 AM
