Old 06-30-2011, 07:52 PM
kidnizmo kidnizmo is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: BIG HORN CREW
Color: WHITE
kidnizmo is on a distinguished road
Default shudder wobble after leveling kit install
well after all my waiting for parts and stuff from HELL BENT STEEL, after my install of 2.5 inch spacer, front alignment and road test, i now have the shudder or wobble or vibration in 4HI. Its prominent when taking off from a stop for the most part and during heavy acceleration. i installed the 2.5 leveling kit from HBS because i had a little over a 3 inch difference from front to back on my truck that has 7k miles. but since i didnt give it enough thought, and my lack of more detailed research i missed the fact that theres an 1/8 inch plate that has to be stacked under the spacer if you have a truck built after 2008. excluding the spacer will damage the strut bushing on top of the strut. adding this stack should be taking in consideration to the overall measurement. since theres only 1/8 inch difference between the 2.5 inch spacer and 2.0 inch the additon of the 1/8 inch spacer will yield a considerable difference in added height. HELL BENT STEEL is sending me exhange 2.0 inch spacer to see if the wobble will go away. note my half shafts are angled downward but not overall too steap to cause issues. if the vibration exist after the install of 2.0 inch spacer then i will remove them and write a code to develope a 1/4 inch spacer on the mill at work.
Old 06-30-2011, 11:39 PM
Bent21606 Bent21606 is offline
Vehicle: 2011 dodge ram
Trim Level: Big horn
Color: grey
Rep:18
Bent21606 is on a distinguished road
i put the Hell bent steal 2.5 kit on with the spacer and no problems here
Old 07-01-2011, 12:07 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I read somewhere that if you get the hell vib dodge is saying to replace you half shaft with their hi performance off road ones.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-01-2011, 10:42 PM
Color: WHITE
Default 2.0 inch Hell Bents installed
i installed the 2.0 inch spacers today, the wobble is barely there. an its brief. its amazing how and 1/8th inch can make a difference. well just have to get the alignment and we are good
Leveling Kit/Death Wobble Poll RamTech Dodge Ram Forum Polls! 24 09-12-2014 11:55 AM
Leveling Kit Install... bcurtiss433 2011 Dodge Ram Forum 5 05-02-2011 06:29 PM
2004 2wd leveling kit install inof please!! MaRvO75 Suspension 15 04-08-2011 04:42 PM
2010 4x4 Readylift 2" Leveling Kit... and NO Death Wobble! jstepy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 35 09-06-2010 01:50 AM
Leveling Kit Install Phoenix, AZ algunn45 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 12-01-2009 12:53 PM
