Oil Pressure drops to nothing, light comes on, truck never skips a beat. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-30-2011, 06:53 PM
FireItUp FireItUp is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie
FireItUp is on a distinguished road
Default Oil Pressure drops to nothing, light comes on, truck never skips a beat.
Happened to me a couple of times over the last few weeks. At stop signs and stop lights, sometimes the oil pressure will drop to zero and the oil light kicks on. But the truck never misses, shudders, knocks, nothing.
A few days ago though, my check engine light kicked back on. I'm sort of thinking a fuel pump, but it could be something else. Any ideas guys? Any would be greatly appreciated.
Old 06-30-2011, 07:34 PM
Kerley Kerley is offline
Vehicle: 1998.5 Dodge/Cummins
Trim Level: Ram 2500
Color: Grey
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Kerley is on a distinguished road
Send a message via ICQ to Kerley
My Cummins does the same thing. I believe the problem is the oil pressure sending unit is worn out and should be replaced. I also have a seprate oil pressure guage that reads the correct oil pressure while the oem is reading 0.
Old 06-30-2011, 10:08 PM
I agree with that ^^^^ as I've had that happen to me as well.
Old 06-30-2011, 10:31 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Agree that the sending unit is to blame. I had an older truck that this happened to.
Old 07-01-2011, 05:16 PM
mcasdorph mcasdorph is offline
Vehicle: 1996 Ram 1500 Club Cab 4x4
mcasdorph is on a distinguished road
Do you have any oil smoke (blue smoke) in the exhaust? I did and I pulled the plugs to check for oil and sure enough in the 8th cylinder I was burning some oil, I was having oil pressure issues, I assume that was my issue, when you talk about stop signs, first thing that comes to my mind is perhaps oil running away from the pump when you slow down, I assume that could give a false warning, but its probably unlikely, do you have any unexpected oil loss when checking with the dip stick?
EDIT* My truck was drinking oil, that was the reason I pulled the plugs.. FYI
Old 07-02-2011, 03:25 PM
Wow...could this thing be in a harder place to get to? There's just the smallest amount of room possible to fit a wrench.
I failed to change it, but I did take a peak down in the intake and noticed it's pretty nasty looking in there. So I figure I may as well wait and change the unit when I change out my plenum gasket.
Any possible catastrophic consequences to not changing this thing out right away?
And I drove my truck down to the auto parts store this morning and the oil pressure never dropped.
Old 07-22-2011, 08:54 PM
JCAMFAC JCAMFAC is offline
Vehicle: 2001 Dodge Ram 1500
JCAMFAC is on a distinguished road
That happened to us, and we found through various forums that the oil pickup tube screen becomes clogged. So I dropped the oil pan, and sure enough, it was almost completely blocked. The design of the oil pan is such that when oil is drained not all of the oil gets out, leaving about 3/4" in the bottom. If you've used cleaning additives, all of the "gunk" goes to the bottom and makes the problem worse.
On our truck I soaked the oil pickup tube in gasoline and it still took a while to get it clean! I also scrubbed the oil pan clean. Although the oil pump was apparently okay, I went ahead and changed it while I was there. PROBLEM SOLVED!
Official Off-Road tire thread!!!! RamCountry Dodge Ram 4x4 - Offroad Discussion 108 06-18-2017 11:19 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Truck overheated, now light shaking rumbling...but no other signs of gasket??? jvigier 4.7L PowerTech V8 Specific Topics 10 04-22-2010 01:40 PM
What would you do? smarthead2006 2009 Dodge Ram Forum 14 01-12-2010 04:18 PM
Oil light and pressure 971500 LD RAM - General Discussion 5 06-19-2009 09:11 AM
