HID Install on aftermarket Projectors with H1 bulbs!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 06-30-2011, 07:31 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Default HID Install on aftermarket Projectors with H1 bulbs!!
I have been reading all afternoon and can not find any information on doing an install with aftermarket projectors!
First all do i just need to the get the H1 hid kit, install and be good to go?
I have heard you need relay harnesses how does that work with the H1, can i get one that will power fogs and low beams?
How is the HID output on the aftermarket projectors i have heard it is not the greatest?
When using a relay harness it only takes the signal from the drivers side, so how do you trick the passenger so you dont get a bulb out warning?
Where should i get my HID kit from? i am in canada so a canadian site would be preferred!
Thanks for all your help!!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-30-2011, 10:03 PM
AWE Daniel AWE Daniel is offline
Vehicle: 2004 Dodge Ram
Rep:27
AWE Daniel is on a distinguished road
Ok so here we go
My retrofit is the Morimoto Mini Projectors (http://www.theretrofitsource.com/pro...au9f0spgqfsral)
I didnt do them myself, but I know that these just fit right in to the housing and I think they twist in, its suppose to be really easy.
Okay so as far as the relay goes, you dont need one. With my HIDs I used capacitors right before the ballast, you can buy them on ebay relatively cheap, I have not had any problems with them. You could also do the resistor trick but then you have to splice into your factory wiring.
And as far as the light output, it is much better than stock housings with HIDs, but it takes a little while to get used to the cut-off. The bi-xenon kit that i linked pulls up the cutoff when your turn the brights on. This is what the cutoff looks like
Old 06-30-2011, 10:06 PM
You won't need anything special for the foglights...those are plug and play.
It's the low beam HID's that will drive you crazy. Contact Jonathan at AAC, one of our supporting vendors here to discuss your needs.
Old 07-01-2011, 02:01 AM
Ruffian11's Avatar
Rep:140
Ya the foglights are gonna be easy!
As for the projector cut-off i already have the new headlights in with just a halogen h1 bulb so i know what it looks like and i like it!
I need to know if relays are absolutley neccesary i read in a few places prolonged use with HIDs on the factory wiring can be bad as it draws alot of amps to fire up the ballasts?
As for the resistors and capacitors will i still need them only doing the low beam side? i have read the a 6a//50w resistor between the power and ground of the low beam would be enough would this solve all my issues if i had any?
Where do suggest getting my HID kits from?
Bought new HID bulbs but have problems str8hemi Custom Dodge Ram Interior and Exterior Lighting 9 09-28-2011 02:39 PM
HID install on SOLAR Headlight assemblies OnceBit Custom Dodge Ram Interior and Exterior Lighting 4 04-08-2011 12:00 AM
6000k HID Install!! 09Ram RT Custom Dodge Ram Interior and Exterior Lighting 15 02-12-2011 02:07 PM
How to install Morimoto Projectors in your 4th Gen Headlights 0212353 Custom Dodge Ram Interior and Exterior Lighting 16 08-02-2010 09:53 PM
