Old 07-01-2011, 01:20 PM
SonsOfAnder SonsOfAnder is offline
Vehicle: 2008 Dodge Ram Sport 4X4
Rep:40
SonsOfAnder is on a distinguished road
Default New exhaust setup and top end bog...
Hey guys! Pictures will be coming soon in another thread....
OK, I went to my local shop yesterday to get a Magnaflow muffler and Y pipe installed. The dude convinced me that the best bang for the buck would be a conversion to true duals. That was a little more than I wanted to spend, so I ended up with this configuration:
They cut off the pipes just after the cats on each side, then welded pipe from each cat back to a dual 2.5" in, single 3" out 14" magnalow (12198). I was concerned about adequate scavenging, but he showed me how the muffler acts as a crossover (?). The pipe is dumped just before the rear axle. Stock resonators both removed. $270.00 installed.
The truck sounds really nice now. Moderately loud, but can be easily covered in the cab with a little radio volume. No drone!!!
Here's the rub. After getting home I noticed that when revved the truck seems to bog in the higher RPM range. Could it be the ECU needs to relearn the proper curve to go with this exhaust? Could this be a faulty approach to routing the exhaust (no y pipe)?
I did install a new CAI that evening (despite the issues), but it did not seem to effect the bog. I do have a DSP in the mail, so perhaps that can be used to diagnose or rectify the problem...
Sorry this is so verbose, but I'm buzzing on my morning java ATM!
Old 07-01-2011, 01:26 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
That is a great setup....Chefred112 runs that on his 12 second quad cab. Pull the negative cable off of the battery for 30 minutes to reset the computer and it will re-learn the new A/F ratio...should be much better after that!
Old 07-01-2011, 01:27 PM
Rep:40
Thanks, man! I'm on my way to the carport now...Will update soon.
Old 07-01-2011, 04:14 PM
916Timmy's Avatar
Rep:1443
Any word yet???? I've got mine unlpugged too! Let it learn the heat of Oklahoma!
Old 07-01-2011, 04:32 PM
Rep:40
Ok guys, I'm back with good news! After disconnecting the battery for 30 minutes the truck runs MUCH better! Top end bog is gone, but it bounces off the governor pretty rapidly. I think the low redline may be a small part of what feels weird to me. I've only had this truck for a week, and I'm still used to a wider power band.
916Timmy, I very much appreciate your helpful reply! I look forward to returning the favor some day.
Old 07-01-2011, 04:33 PM
916Timmy's Avatar
Rep:1443
De nada! It's why we are ALL here! Good idea to do this with any new engine mod!
Old 07-01-2011, 04:47 PM
Rep:40
Rep to you 916T!
Old 07-01-2011, 11:00 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
were you revving it in Park or Neutral? If so, Dodge has a cutoff programmed in somewhere around 4000 RPM.
Old 07-02-2011, 02:55 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
my setup is the same way..just a lil bigger...and chevy killer is right, to protect the motor, there is a governor in park/neutral at 4k rpms, with a diablo you can increase it..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 07-02-2011, 12:12 PM
Rep:40
Yes, I was revving in in park....that would explain the narrow power band, LOL! This stuff is a lot of fun, but a bit nerve racking considering I don't really know what the hell I'm doing.
I will say that after driving the thing quite a bit more yesterday after my last posts that I do have drone. It's more noticeable at moderate speeds (35-50) than at highway speeds. When I'm at 65-70 mph and it kicks in it is quite tolerable (even pleasant?), but on secondary roads it sounds a lil' poopie....especially right at the speed where you'd begin to benefit from having your overdrive turned on.
I can't really tell if there's much difference in the power. In fact, it seems a bit sluggish in certain areas of the power band. I kinda wish I had waited until I had this 100% sorted before putting on the CAI.....DSP should be here in a few days. I can't wait to see how much trouble I can get in to with that!
Fast Freddy, for what it's worth, I was thinking of your setup when I agreed to have mine configured this way. I remembered reading many posts regarding your BAD AZZ truck. Props!
