A/C air flow path - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-01-2011, 05:40 PM
Spartan Spartan is offline
Vehicle: 2011 Ram 1500
Spartan is on a distinguished road
Default A/C air flow path
I'm want to find out if the flow of the a/c air (when set on max) goes through the heater core or if the recirculate door changes the path to bypass the heater core.
I have a mod in mind to make the ac colder.
Thanks for any info.
Old 07-07-2011, 08:30 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer, my guess based on a fix I had to do when a napkin was sucked out of my glovebox and into the fan motor when on recirculate is no, but, it's time to .................... this back to the top!
Old 07-07-2011, 01:09 PM
DTarve23's Avatar
DTarve23 DTarve23 is offline
Vehicle: 2006 Dodge Ram Quadcab
Rep:25
DTarve23 is on a distinguished road
the blend door when set all the way to cold bypasses the heater core and as you rotate the temp control knob to hot i gradually opens up the blend door to the heater core to adjust the temp but the heater core and the A/C evaporator coil are very close together so i have seen in other threads were they put a ball valve inline under the hood to restrict water-flow to the heater core to prevent heat-soak into the evaporator coil area I have never personally tore down the entire dash of my dodge other than to check blend doors and clean the evaporator coil (without removal of dash ) but from what i understand its just a thin plenum that is between the heater core and the evaporator coil
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 02:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
2001 Dodge Ram Air Conditioning westbygodtbone Heating & Cooling 1 05-03-2011 10:18 PM
Mass Air Flow Direction alharm1 LD RAM - General Discussion 5 03-08-2011 09:33 PM
Air flow dmtonka 5.7L V8 Specific Topics 4 03-01-2011 10:06 AM
