Old 07-01-2011, 06:38 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
Exclamation coil springs-clarification
so just to make sure that I have this correct, you can replace your coil springs with springs that are 2 inches taller than stock to level your truck and thats perfectly safe and doesnt hinder the trucks ride, or put stock size shocks at risk? thanks for the info guys
Old 07-01-2011, 07:47 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Yeah. Most leveling kits are a spacers, if your going to replace the spring I would get a longer shock.
A leveling kit puts your stock length shock at its travel limits so its not exactly the factory quality ride your used to.
Old 07-01-2011, 08:01 PM
The Codes's Avatar
Rep:44
yeah I was looking into getting some skyjacker springs that are 2 inches higher than stock to level my truck instead of getting spacers...do you think the shocks would be okay without being replaced? cuz I just put those new oem size Rancho shocks on like 200 miles ago...
Old 07-01-2011, 08:10 PM
Rep:2657
I think some Bilstein adjustable shocks may be in your future
Old 07-01-2011, 08:12 PM
Color: Mineral Gray
Rep:177
A skyjacker spring is going to ride different then stock. Just different spring rates.
Your stock shocks will be ok. The rides not going to be very good and there is a greater chance of blowing your shocks out.
I have a 2" spacer on my 2500 and ran stock length shocks for almost a year without problems. I just put on es9000 +2" shocks on and the ride is much better!
I cant find the 2" springs alone but for as much as their spacers are I would probably just go with a Hell Bent Steel Spacer and spend the extra money for longer shocks
Old 07-01-2011, 08:15 PM
Color: Mineral Gray
Rep:177
98's have solid front axles and you cant use the ride height adjustable shocks
Old 07-01-2011, 08:24 PM
The Codes's Avatar
Rep:44
I was looking into getting a spacer from hbs but it didn't look like they make kits for 2wd. I guess I have some decision making to do...
Old 07-02-2011, 11:10 AM
Color: Mineral Gray
Rep:177
Well I didnt realize it was 2wd. I'm not sure what the difference between a 2wd spacer is and a 4wd spacer but try this out http://store.fatbobsgarage.com/52l-v8-fi-c5274.aspx
They have a bunch of different options height for your truck
Old 07-02-2011, 11:23 AM
The King's Avatar
The King The King is offline
Rep:15
The King is on a distinguished road
There's so many different leveling kits out there, how do you decide?? I have plans to level my 98 1500 4x4
Old 07-04-2011, 08:20 PM
The Codes's Avatar
Rep:44
do you think the spacers are a better option than new springs? A few other people have told me that a spacer would give a rougher ride than springs, and that then there is no doubt the spacer will ever fail or slip out or anything like that.
Tell me about the Coil Springs slidellkid 2011 Dodge Ram Forum 9 04-04-2011 05:46 PM
2500 coil springs/ 3500 coil springs JaM Customs Suspension 3 02-08-2011 07:40 PM
Question for those with the McGauphy kit(spindles and coil springs) gonzo1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 10 10-23-2010 09:17 PM
Question concerning rear coil springs Quiet Lunatic 2010 Dodge Ram Forum 3 02-05-2010 09:26 AM
Spindles or coil springs? RadRam Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 11-19-2009 10:31 PM
