coil springs-clarification - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-05-2011, 11:02 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
For choosing a leveling kit you should measure from the center of your axle to the lip of your wheel well in the front and back and the difference will tell you how high to raise the front.
I think in your case a spacer would be a better option, but its just my opinion. The spacer itself won't give you a rougher ride, its using the stock length shock with a leveling kit that gives them rough ride (so with a spring or spacer). Your ride will stay closer to the way it rides from the factory with a spacer and extended shock rather then a leveling spring and extended shock because the leveling spring will have a different spring rate.
Most spacers are either computer welded steel or a nylon-type material like the bushings and body mounts of your truck. The chances of them failing are almost as unlikely as them slipping out (they are bolted to your strut tower and have a groove that sits inside the spring, something has to go extremely wrong for them to actually slip out and in that event a regular spring would too)
Old 07-05-2011, 11:23 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
alright thats really good advice, will do those measurements tomorrow. thanks for pointing me in the right direction
Tell me about the Coil Springs slidellkid 2011 Dodge Ram Forum 9 04-04-2011 05:46 PM
2500 coil springs/ 3500 coil springs JaM Customs Suspension 3 02-08-2011 08:40 PM
Question for those with the McGauphy kit(spindles and coil springs) gonzo1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 10 10-23-2010 09:17 PM
Question concerning rear coil springs Quiet Lunatic 2010 Dodge Ram Forum 3 02-05-2010 10:26 AM
Spindles or coil springs? RadRam Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 11-19-2009 11:31 PM
