Place your Ad Here!
Old 07-02-2011, 01:29 AM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
Default 1/2 to 3/4 ton suspension
Hey guys and gals, I got a 98 1500, 4x4 sport. I've been building this truck little by little, but now Im on to the suspension. I'll be honest, I was raised runnin and buildin fords so they are what I know. I know with the generation of them i was runnig, you could swap over 3/4 ton suspension to a half ton just like replacing the 1/2 ton suspension. I was wondering if it can be done on the dodges to? This truck is my daily driver, do a little wheeling with it, but use it as a truck to. I know it will ride like a brick $hit house, (thats the only good phrase i know to describe it), but I also know, it'll give it a little bit of a lift, and extra carrying capacity. So, is it a matter of just swapping out the leaf springs in the rear, and the coils in the front, as well as new shocks? or won't the heavier leafs and coils come close to fitting? TIA
Old 07-02-2011, 01:41 AM
Rep:2910
i am not sure about the suspension on a 1998 Dodge truck
but doesn't the rear end have LEAF springs?
if it does, you can add or remove leafs to get the suspension that you want or need
some are full length, some are helpers, maybe 1/2 the size
In my area there is a spring shop, you tell them what you would like to have & they give you options, they also suggest shock absorbers to go with the options
they can heat your springs up & put an arc in them or flatten them out, you name it, they can do it
Old 07-02-2011, 05:17 AM
99 ram slt's Avatar
99 ram slt 99 ram slt is offline
Vehicle: 1999 dodge ram 1500 4x4
Color: blue/sliver
Rep:17
99 ram slt is on a distinguished road
can can put the 3/4 ton springs on ur half ton and bolt right up jus make sure that u get the same width rear springs as whats on ur 1/2 truck.
Old 07-02-2011, 11:21 AM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
is it a ifs front or solid?
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 07-02-2011, 11:53 AM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
Yeah you can swap coil and leaf springs over to your truck and if you want the axles are even interchangeable, no modifying needed.
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 07-02-2011, 01:35 PM
Rep:26
Thanks, yes the rear are leafs, and yes the front is coils. It is solid front end. As to adding leafs and what not, thats all fine and dandy if you wanna come and do it, but I'll still be stuck with the factory leaf springs that have 146k miles on them that I dont know what they were put through. Its time for new. That's good to know about the axles to, as those might be in the future as well.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 168 01-27-2017 06:08 PM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
2002 Towing / Suspension MODS jlwest60 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 05-29-2011 11:44 AM
Body lift vs Suspension lift ccga3359 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 12-19-2010 09:22 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 05:57 AM
