Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-02-2011, 02:50 AM
bigred bigred is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: crome
Color: infernal red crystal pearl
bigred is on a distinguished road
Default ac pressures
my truck wasnt cooling very good so I checked it at 85 outside I got 35 lbs on the low side I charge one can on the low line and later around 95 outside its now around 42 lbs the low side line isnt as cool but inside it feels cooler so is it overcharge ? befor the line was cool but allso very very wet I was told not to go buy the instruction on the tester I got any infor would be nice thanks
Old 07-07-2011, 09:37 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-12-2011, 05:32 PM
Trim Level: crome
well the shop said theres differant pressures then what the kit said theres were higher but seems ok now with the heat 85 to 100 was better cooling was told 50 at 95 to 100 temp so just seeing how it goes now dont think its overcharge so will see all summer
Old 07-13-2011, 12:44 PM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Don't you have any warranty left? I would be taking it to the dealer instead of just adding gas. If your evaporator is on the way out you will be glad you're not the one paying to replace it.
Old 07-13-2011, 03:23 PM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
I am assuming the can has a pressure gauge on it. The easiest way to tell is your system is under or overcharged is by using this chart & calculator. http://www.csgnetwork.com/r134apresstempconv.html
It compares static pressure to ambient temperature. This will give you a general idea if your truck is over, under or perfectly charged. This chart applies to any vehicle using R134A.
Now to test your truck: Let the vehicle sit without running for 1-2 hours. This allows you high & low side line pressures to equalize.
Hook up the pressure gauge & with the engine still off check you static pressure. Note this number & the outside temp.
Go to the chart and find the temperature that matches your ambient temp.
If your pressure reading is higher than the chart then you are overcharged.
If your pressure reading is lower than the chart then you are undercharged.
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 07-13-2011, 03:32 PM
Rep:12
One other thing i wanted to toss out there. Its an industry standard to have you AC vents blowing air that is around 30 degrees cooler than the outside air. This temperature reading should be taken at the AC vent closest to the evaporator. 99% of the time this will be the passenger vent closest to the passenger door.
Sometimes it will be colder that 30 and sometimes it will be less. Humidity plays a huge factor in efficiency. 70+% humidity levels will have the most significant impact on your systems performance.
Just remember to ensure the HVAC controller is set to recirculation to provide the best efficiency. This allows the system to remove more heat from the same air over & over VS introducing hotter air that requires a lot more heat to be removed.
Old 07-23-2011, 02:53 AM
Trim Level: crome
thanks for all the help one can worked perfic dealer said it was fine ya sure not going back there I leave town to go to another dealer if I have too my friends shop says its ok seems if it free then you get what ever they feel like giveing you ! bs is all I am seeing at that dealer hopefully I never need to go in thanks again !
Incorrect door sticker tire pressure recommendation steve57 2010 Dodge Ram Forum 48 09-29-2010 11:38 PM
What is correct: 30psi; 35psi or 40psi? steve57 2010 Dodge Ram Forum 50 09-24-2010 11:17 AM
Ashamed to ask but... Mac Dodge Ram Wheels And Tires 12 06-30-2010 11:10 PM
