Old 07-02-2011, 03:08 AM
sthenaire sthenaire is offline
Vehicle: 2001 dodge ram 2500
sthenaire is on a distinguished road
Default cat delete 02 simulator
hey everyone, new to the mopar scene here and having issues with my exhaust. ive got a 01 ram 2500 5.9 v8. Just got a flowmaster super 44 single in dual out muffler 3"in 2,1/2" out. it sounds weak, comparable to stock. im going to eliminate the cat but was wondering what to do about the CEL thats going to come on. Ive been to thefastguy.com and was wondering if anyones used his simm for the post cat 02 sensor and how it worked. Also if theres any other simmulators out there people have used. If anyones got any insight feel free to chime in. Thanks!
Old 07-02-2011, 06:40 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Exactly what problems are you having? From my experience (gm background) the rear o2 sensor only does one thing, and that is to monitor the condition of the catalytic converter. So, if you don't care a bout the light showing up and ignoring it as you don't have any other side effects, you should be fine. If you can't stand the little light like me and most other people, you may be able to trick the computer yourself. With gm vehicles, you can you two spark plug non foulers (basically a spark plug spacer) and put them in between the exhaust and the o2 and it will usually keep the light from coming on just by putting the sensor out of the exhaust stream. You may have to drill the center of one spacer out a little to get the o2 sensor to fit inside it. Thread sizing is guess and check. That being said, why do you want to remove the cats? You really should run them...especially if it's a street vehicle. I removed cats on 2 previous vehicles, and found on a dyno that they were only holding back 2hp at peak power on one of the vehicles....really doesn't hurt anything...I will always have cats on going forward, you can buy cheap aftermarket cats pretty reasonably priced...
Sean
Old 07-02-2011, 11:24 AM
its not i have a problem with it its that it has no sound with the flowmaster and duals. its comparable to stock, and i mise well take the cat off to get the sound because a highflow cat is still going to throw a CEL. also the post O2 sensor will put the computer in safe mode if it detects a faulty cat. the light needs to be off for inspection thats about it, doesnt bother me any haha. 95 and down chevy onle have pre cat 02 sensors ive had 5 and decided with a mopar this time and the sound alot better without the cats then with them but thats just my oppinion, can you explain more about the fouler trick?
Old 07-02-2011, 11:34 AM
snrusnak's Avatar
Rep:1385
like this....
http://www.ramforumz.com/showthread....ghlight=fouler
Sean
Old 08-06-2011, 10:55 PM
moparman360 moparman360 is offline
Vehicle: 01 dodge ram 4x4 qc sport
Trim Level: sport
Color: intense blue perl
moparman360 is on a distinguished road
Default ill bur huckaberry
$4.50 is the price you pay for a o2 deleat look it up on the net you go to raido shack and pick up what thelist says and wire it in. done for $4.50 $4.50
just a good ole boy sippin and dippin
Old 08-07-2011, 12:09 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
I have no cats and still have the stock o2 sensors hooked up...no light and its been like that since 80k miles, and it has 160k now.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 08-08-2011, 09:50 PM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
I put a Magnaflow Cat setup on mine and it didn't throw a light... and it sure as hell opened her up!
Old 08-08-2011, 09:57 PM
MoparGuy86's Avatar
Color: Faded Gray
Old 01-19-2013, 09:41 AM
slowram slowram is offline
Vehicle: 2005 Dodge Ram
Trim Level: Hemi Sport
slowram is on a distinguished road
great info here!
DPF and EGR delete and the LAW Dooner Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 3 07-01-2011 08:14 AM
egr delete on predator Rumble13 Diablo Predator Questions & Info! 5 03-19-2011 10:32 PM
DPF Delete macsbees 2010 Dodge Ram Forum 3 10-15-2010 02:21 AM
EGR codes after a DPF delete? lancinator Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 1 09-27-2010 09:34 AM
Cat Delete Redneck24V Exhaust 8 09-06-2010 05:35 PM
