Old 09-24-2011, 11:50 PM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
What are these running as far as price goes and how often do you have to empty it?
If i can kill it with an arrow, I'll eat it.
Old 09-24-2011, 11:58 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
I got mine from speedlogix, around $110. I got the braided lines so that raised the price a little, make sure you get the z-bracket. Empty it every couple thousand miles, best to get in the habit of doing it when you change your oil.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 09-25-2011, 12:12 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
lookin good bud also one of the many more mods on my list
Old 09-27-2011, 08:17 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
Which catch can did you buy, I looked at the site and they don't have one listed for the ram....
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 09-27-2011, 08:55 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
You guys must be made of money. I wasn't going to spend over $100 on a catch can, so I made my own. Looks almost like the pic in post #1, and only cost me about $10 using regular household items.
www.beatcraigslist.com - for posting dangers & secrets
Old 09-27-2011, 10:35 PM
AzHunter's Avatar
Rep:52
Question
How about some pics on your Home Made Can. U got my ear, or eyes as it may be...
Old 09-27-2011, 10:49 PM
moparornocar72's Avatar
Rep:630
Yes pics or it didnt happen
14.268 @ 95 MPH Full Trim
Old 09-27-2011, 11:19 PM
Rep:55
Haha, fear not, I do not boast about something I didn't do. OK, I'll include a few pics and tell you what I did. I did a bit of research first and gathered the best ideas I could find and tried to incorporate it into my design. At first I tried using a compressor water/oil separator, but I found that didn't work so well. Since those are made to hold pressure, they it didn't hold suction so well, so once I found it was leaking air I scrapped that idea. So next I decided to build one myself. I looked around the house and being a DIY person, I keep all my extra left over stuff. So I dug up some old ABS pipe, left over epoxy, old screen mesh, old piece of vinyl trim and put it all together. The only parts I had to purchase where the hoses, the fittings, and two end caps, all total less than $10. Now this design fits my 97, but all you need are different fittings, hoses and a bracket to suit any year vehicle. So the crux of it is I used the 1&1/2" ABS pipe as the housing, and the vinyl trim piece as a divider. This way the air has to travel around the divider to get to the other side. Then I used the screen mesh to grab the large oil particles out of the air. At the bottom I made a hole to act as the drain. Then I painted it all black and the rest is history. If there is anything I missed, just let me know.
I'm building another one for my Mustang right now and that one will use larger fittings and hoses.
Old 09-27-2011, 11:48 PM
AzHunter's Avatar
Rep:52
Very interesting.... My question is how long have you been running this and what part of the country do you live in? I can't imagine that PVC and glue are going to hold up that long where it is 120 degrees through the summer and adding 200 degree vapors and oil to it.
Nice write up though.
Old 09-28-2011, 12:15 AM
Rep:55
I live in SOCal so it gets pretty hot here, and much more humid than AZ. I have been running it a couple of months and no problems. A couple of things to consider. First, it is not plastic, but ABS pipe which has to hold up to all sorts of plumbing conditions in a house for decades. That is some left over pipe I had from a sink install. If it can hold up for decades in a house, I think it will be OK. Also the vinyl was from some trim I installed around windows over ten years ago. The trim that I installed (this was left over) has stood up to sun, rain and cold with no cracking, fading or chipping, so that I am also confident of, and I didn't use glue, I used epoxy. This stuff bonds like nothing else. If you prep it correctly, good luck breaking it apart. I can't open this can up for nothing. It is all bonded shut permanently. You should also keep in mind that the suction is constantly blowing (or sucking) air through the inside of it so it ventilates it and keeps the heat from really building up. I have touched it after driving for a couple of hours, and while it is warm, it is not scalding hot. I can grab it without having to pull back. I have opened it up a couple of times to make sure that it is catching oil, and that the drain is big enough for the oil to flow out.
Free Power! Throttle Body Mod bigtallcampbell Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 85 02-19-2012 08:29 PM
Excessive Throttle Body Noise firedog318 5.9L V8 Specific Topics 8 01-23-2011 02:54 PM
Normal price to install body lift? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 01-07-2011 12:07 PM
body moldings with two tone pics to share? Mopar steps vs aftermarket? EZdown Help ? Quiet Lunatic 5.7L (345 cu in) HEMI V8 Specific Topics 5 01-04-2011 09:47 PM
