tonneaucovered.com
Old 07-02-2011, 07:45 PM
Wayne084 Wayne084 is offline
Vehicle: 2011 Ram 1500
Rep:53
Wayne084 will become famous soon enough
Default Startup problems
If I start my truck too quickly when cold, and when I start it in the morning, it makes this really raspy noise that sounds like the motor is going out of it, then it stalls itself out after about 7 or 8 seconds. I had to try 5 times before it would work this morning. It doesn't send any codes or anything. Does anyone have any idea what's happening. No one else I know that has this style truck has to wait to start it or anything. Also when I am sort of idling along in 5th gear it sort of makes this quiet grinding noise in the motor or something when it's idling along (with MSDS off). Is that normal? I have to goto the dealer pretty soon since the bearing on my fan motor is going (makes noise when idling in certain positions).... Not bad for a truck with 3500 mi, eh?
Anyway, does anyone know what this start up issue could be?
Old 07-02-2011, 10:47 PM
hmmm...interesting situation you have there.
Do you turn on the key, wait 5 to 10 seconds for the fuel system to pressure up, then start it?
Old 07-03-2011, 03:56 PM
Rep:53
Usually I wait until the red light goes off (that seems to be about when the fuel pump stops). It happens less frequently when I do it that way, however I am the only person I know around here that does that. Everyone just hops in and jams the key to start, and none of them have this problem with their trucks.
Old 07-03-2011, 04:20 PM
I have that problem with my truck if I don't wait for the lights and chimes to stop.
Check the throttle body and make sure it doesn't need to be cleaned.
Old 07-03-2011, 10:23 PM
nikeman nikeman is offline
Rep:91
I usually remote start my truck and haven't had any starting issues yet
Old 07-04-2011, 09:40 AM
Bent21606 Bent21606 is offline
Vehicle: 2011 dodge ram
Trim Level: Big horn
Color: grey
Rep:18
Bent21606 is on a distinguished road
ive had those problems remote start or not. seems to happen more depending on witch gas station i use
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 11:32 AM
Paint problems crazygreek89 Body & Interior 3 04-30-2011 06:09 PM
Flashing CEL and shifting problems al4171990 5.2L V8 Specific Topics 12 03-26-2011 12:28 PM
fuel problems dieselonroids Cummins Diesel Specific Topics 4 10-09-2010 09:29 PM
Oil pressure problems at startup Quiet Lunatic 5.7L V8 Specific Topics 5 09-13-2009 12:00 PM
