Old 07-03-2011, 03:20 AM
silverd silverd is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Color: Mango
silverd is on a distinguished road
Default Leveling 2005 Quadcab 1500 2wd Hemi
Hello all. I am trying to decide on how to Level my 2005 QuadCab 1500 2wd Hemi Daytona. I am trying to decide between a CST Suspension 3" Lift Coil which they say is not designed for the Hemi, and a Spacer. I would like to go with Bilstein shocks, since I hear they really make a difference over stock. Even stock would be a huge improvement.
I'll start with a little background. The truck was a theft recovery, and when I got it (cheap $8K w/63k miles), it had the wrong wheels (17"), and a lowering kit. I don't want it lowered anymore. No offense to those people with lowered trucks, I like the look, but driveabilty it doesn't work for me. It bangs on every bump, and my wife doesn't like the feel of the ride. Note: She drives an 04 Durango, so the 05 Ram shouldn't be too different. The way they lowered it is by changing the Coil Springs, and a Flip Kit in the back. I believe it still has the stock shocks. Right now there is only 3 1/4" (front) and 3 3/4" (back) clearance from the top of the tire to the inside top of the wheel well (basically level). I like the level look. I just got a set of 22" SRT-10 Wheels w/brand new Nexen 305/45/R22 Tires to put on it when I am done with the suspension.
I am leaning towards a leveling/lift Coil Spring, because I have to change the Coil Spring anyway. I suggesting the CST because I may be able to get one cheap. I am open to other Lift Coils though. Part of me thinks if I go with a spacer and a stock shock with or without a shock extension, I can always convert it back to stock if I choose to.
I'll break my first set of questions into 4 groupings, for all these please let me know how you like the ride mainly for street use (approx 95% of the time). I do want to tow and haul a little, but I believe I can always use air helper bags for that later.
1) I would like to know if anyone is usng the CST Suspension (CSC-D3-2)? If so what shocks, do you have the Hemi, and how is the ride?
2) Using CST w/Bilsteins. If they are, did they use the stock ones (24-069274), shock extensions, or the ones for the 2500/3500 (F4-BE5-C603-HO / 24-186063)?
3) If you are not using the CST Suspension, but are using the Bilsteins with a Coil Spacer, please let me know how you did it, and how it rides? Please tell me the size of the spacer/company, and which Bilstein shock you went with. If it is the Bilstein for the 1500, did you use a shock extension? If shock extensions what size, brand, and where did you get it?
4) Not using CST or Bilstein. Please let me know what you did and if you like it.
Next I was wondering if anyone has the Specs on the two Bilstein shocks I mentioned above? I've searched the Internet and can't seem to find specs for them (extended and compressed lengths).
Lastly, I would like to get recommendations on Rear Air Helper Bags for hauling and towing. Please let me know your thoughts/recommendation, and what you've been using them for?
Thank you for taking the time to read this & hopefully responding.
Old 07-04-2011, 02:57 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Well I can't comment on much but the shocks really.
My leveling kit (spacers) just came in and the new Bilstein shocks are going up front also. I bought the 2500 stock length shocks because they are 2" longer than the 1500 models.
For reference Bilstien F4-BE5-C603-HO are the same ones I bought.
Old 07-04-2011, 03:55 PM
Trim Level: Daytona
Color: Mango
Default Rammin
When your done installing, let me know how the ride feels. I would also like to know who's 2" spacer you got, where, and if you installed it the way they recommend(with original bushing on top of the spacer). Thank you.
Old 07-04-2011, 04:06 PM
Rammin's Avatar
Rep:44
Will do but it will be a few weeks. I've got birthdays out the wazoo this next weekend and then I'm on vacation for a week.
My plan is to do it myself and leaving the original bushing as well. My spacer was a 2" poly spacer from daystar. Got it on ebay much cheaper than anywhere else. Also got the shocks there too. I've lifted tons of trucks so this should be fairly straight forward.
4x2, level, leveled, levelled
2005 ram 1500 hemi automatic stalls davidjohn819 5.7L V8 Specific Topics 1 04-08-2011 11:22 PM
Thoughts on '03 Ram slt 1500 hemi reg. cab BlueMonkey Dodge Ram General Discussion 2 03-15-2011 06:34 AM
Newbie..looking to upgrade my 2005 1500 Hemi CALIRAM Dodge Ram Wheels And Tires 2 01-30-2011 12:54 PM
Need Tires & Want Leveling Kit for '06 Ram 1500 CJonLI Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 07-25-2010 03:46 PM
What year of factory wheels will fit my 2003 Dodge 1500 quadcab? Dhunter Dodge Ram Wheels And Tires 3 04-26-2010 02:08 AM
