Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-20-2011, 11:18 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Originally Posted by sonocativo View Post
I hope so, at least for the rest of this year... Here is the quick fix I did as a precaution...
I meant to say awhile back that you can actually replace that leaking valve. It unscrews off the line, if you choose to replace the valve make sure you don't overtighten it, A/C systems are sealed by o-rings so overtightening will only damage threads and that will end up leading to a big problem, anyways that valve is a high side valve you can pick one up for 6 bucks at autozone, I have two i keep as extras incase cause like i said mine was leaking but it doesn't leak anymore however my schrader valve on the low side is leaking but I won't replace the valve until the system is empty again. lucky for you your ac lines are aluminum while mine are steel so mine will rust away. but yea that valve you have that was leaking is replaceable.
Old 07-20-2011, 11:31 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Thanks, I cant seem to find the same valve ( and I dont know much about them ) Mine looks like a little ball inside, the new ones look like car tire valves... are they the same just replace the whole thing with the new style valve?
Mike
Old 07-21-2011, 12:16 AM
ramvan2500's Avatar
Rep:128
They can be difficult to find, they were used mainly on the older ram's for a short time for very obvious reasons. The valve on the high side is known as a service port and the valve on the low side is known as a schrader valve (looks like a bicycle valve).
Anyways the valve you want to replace is fjc inc 2609. It's run about 99 cents on the internet. just google "fjc inc 2609" and you will find it. If you have a problem trying to get one I can probably send you one, you could replace it with the newer style valve if you wanted to but I don't really see a reason to since the newer style valves leak as well. I would recommend to replace every 6 years the hi and low side valves, the system o-rings, the drier. Be sure to evacuate the system on both high and low side with a vacuum pump that can withstand a holding vac of 28 in Hg for atleast 1 hour, be sure you evac for about 45 minutes don't evac for to long because you could actually damage components but it is very rare. If you have a large system like me which uses 6 canisters of refrigerant then it's smart to vac for about 1 and half hours.
All this aside it is hard to find the valve but not impossible. You could try a junk yard, a tip if you do go to the junk yards you will find that service valve on dodge ram van's typical year is around the middle 90's. you can remove the valve with a channel lock plier with no issues, again valves and hoses aren't to be tighten to much because it's mainly aluminum and it would strip thread easily. tell me if you come up with that valve.
Old 07-21-2011, 12:25 AM
sonocativo's Avatar
Rep:210
Thanks for the info... I will check it out and let you know, Hopefully my wife will let me spend another dollar as she just ordered me 2 pounds of Cedar Creek Jerky.... I love the stuff ! LOL
Mike
Old 07-21-2011, 12:31 AM
ramvan2500's Avatar
Rep:128
Yea just take it easy on the jerky thats a cardiac infarction waiting to happen... Anyways the side that is leaking is the high side not the low side, low side uses schrader the high side uses older service ports. And of course you know but I just like going through the ritual of instructions to be sure that you only allow the refrigerant to enter into the low side as a gas only. Be sure to purge the service line on the manifold of any air when changing cans if you're using cans. and all that stuff, I found out that shaking the can rapidly helps empty the can out faster also when you add refrigerant through the manifold that you don't open the low side valve all the way only open it maybe 25% then move onto 50% this ways you can allow a very steady stream of refrigerant because as long as the can has more pressure than the low side you can release the gas 134 into the low side.
If you are unable to get that valve I can give you one, but I will only give you one if you certainly cannot obtain a valve. I horde the valves because I know they aren't easy to find and aware of their failure rates. Autozone sells a similar valve but I'm not aware of the size of the thread. But I will order one to find out.
Oh and if you're looking for a deal on 134a Big Lots sells 12Oz cans for 8 bucks each.
Old 07-21-2011, 12:50 AM
sonocativo's Avatar
Rep:210
Now you tell me...lol I bought a can at Oreillys the other night because I was hauling some stuff today for a buddy and I needed the ac out there in the heat...whew its hot out 115* heat index and getting higher as the week goes. I will have to hit up big Lots before I change the valve, I got a buddy who has ac equipment but cant get ahold of him hardly, but I can buy a vac for $109 on amazon, so far the valves I pull up dont work on my 97 1500 360???? as it says when you enter the info?
Mike
Old 07-21-2011, 12:52 AM
sonocativo's Avatar
Rep:210
Oh, and as you say the low/high side... I add the 134a at the port in front by the radiator, it fills and gets colder as well as empty the can , The cans come with the hose/fitting and it fits on with no leaks or anything so I assume its the low side...lol
Mike
Old 07-21-2011, 01:31 AM
ramvan2500's Avatar
Rep:128
I'm guessing from you uncertainly that you have really no idea what you're doing. So I am going to help you on this, if I lived near or vice versa I would do it for 20 bucks. But heres the brake down.
You have two valves on is high side (largest valve) and one is a low side (smallest valve). Obviously the low side is lower pressure typically between 30-50 PSI and the high side is high pressure anywhere from 125-300 PSI.
When low side pressure increases so does the high pressure, however it varies based on temperature variables.
You have a evaporator and a condenser. The condenser sits outside the vehicle probably infront of the radiator and the evaporator sits some place inside the dash. The evaporator is gets cold the condenser gets hot, what the condenser does is to boil down the liquid refrigerant into a gas again, 134a boils at around -26 C.
The filter drier is basically a can with a dessicant that is used to remove moister from the system and it also stores liquid refrigerant incases of overfill and loss. It is wise to replace this part after so many years, thats why I say every 6 year overhaul the whole A/C system.
Then you have expansion valves, these control the flow of refrigerant, these typically don't have to be replaced normally the thermostatic ones do though. BTW Their are 3 types of expansion valves.
The system is sealed with O-rings, when two fittings connect their is an oring to seal it, when you connect a valve to a line o-ring. O-Rings to be replaced every 6 years blah blah blah.
Ok then you have you compressor which I'm sure you know about. And lastly you have your refrigerant oil and refrigerant.
Normally you don't have to add oil to the system usually the compressor is shipped with a fixed displacement of oil however sometimes you do have to add oil when you replace alot of parts that had stored oil or when you have an additional A/C system like in the vans, etc... The oil is basically used to lube the compressor and to keep the system from rusting from the inside out.
The refrigerant well nothing to say their, you can use many things as refrigerant, propane, butane, etc... But stick with 134a.
Now to move on to the tools of this flimsy trade.
You have your manifold, vacuum pump, and thermometer.
Ok their are two types of manifolds R12 and R134A. But we will only talk about 134a.
To start off the manifold has two hand valves a low side and high side, it has two gauges high side low side, and has two quick connect couplers high side and low side and on the couplers you will find little valves turning it clockwise opens it and counter clockwise closes it.
Then you have your hoses, you have a red one which is high side and blue one which is low side and then the yellow hose known as the service port. The yellow hose will connect to things like vacuum pumps, refrigerant cap taps, and of course the manifold it self to make a sealed loop.
Ok to start off, if the system is in need of repair make the repairs then fallow.
Connect the low side coupler to the low side valve on the vehicles ac system, then connect the high side coupler to the high side valve. Be sure the valves on the manifold are closed.
Now open the valves on the couplers by turning clockwise. Ok be now connect the yellow service hose to the vacuum pump.
Turn the pump on, then open the low side valve on the manifold then open the high side valve on the manifold, open these valves 100%.
Now let the vacuum pull in 28-30 in Hg for about 1 hour, this vacuum will eventually cause what ever moister or water in the system to boil to a vapor and will be sucked out.
Ok now close the high and low side valves on the manifold then turn the pump off and disconnect the hose from the pump. Now to check for leaks look at the manifold's low pressure gauge and read the vacuum, then come back 30 minutes and observe if the vacuum has decreased, if it has then their is a leak if not proceed.
Now we will skip adding oil, now to add refrigerant using those little 12 Oz cans. You will need a can tap so we will say you have one already.
THE HIGH SIDE VALVE ON THE MANIFOLD WILL ALWAYS BE CLOSED NEVER OPEN THAT VALVE.
Take the can tap and turn the valve counter clockwise and then screw the tap onto the can, then connect the yellow hose to the tap. Now turn the valve on the tap clock wise, this will open the can. Now turn the valve counter clockwise to open the valve, then at the manifold side just loosen the yellow hose and allow some of the refrigerant to escape this will purge any air from the service hose, air in the system will shorten the life of the system and will also contaminate refrigerant thus making it useless meaning that the system won't cool as effectively as it could.
Ok once you let some of the air out (about 4 seconds) tighten that hose back up, now you can begin to add refrigerant to start off you can put the key in the ignition and start the car. Then with the car running turn the A/C on the maximum settings then go back to the manifold and turn the blue (low side valve) on slowly until it's opened 100%, you will want to shake the can left to right rapidly, make sure the can is up right because you don't want liquid refrigerant on the low side, the low side cannot handle liquid refrigerant very well. The first can will empty out quickly and the can will get very cold so wear gloves. It will only take about 7 minutes to empty the 12 oz can, during the first can the compressor will cycle on and off until their is enough refrigerant in the system to keep the compressor from burning up. Ok once the can is empty you will shut off the low side valve on the manifold. Then loosen the yellow hose at the manifold a little to allow the residual pressure in the can to release. Once thats release you can remove the can then install the next one.
Be sure to fallow the same purge procedure for each can.
When you remove the couplers from the valves be sure you close the valves on the couplers first then remove the couplers, you can allow what ever gas is left in the manifold to release by unscrewing the yellow hose and opening both high and low valves on the manifold. Don't let the refrigerant or oil get on you.
You can get a manifold at a harbor freight for 40 bucks or you can go to autozone get one for about 50 bucks or rent one for 90 bucks (it's refundable)
The can tap runs you about 7 bucks. The refrigerant like I said 8 bucks a can at big lots
You can also get a vacuum pump at harbor freight for 100 bucks.
If your wondering about the high side valve why is it even their, well their is many ways to add refrigerant, the slow way is gas and the fast way is liquid, Liquid goes in the high side and gas in the low side, but don't try the fast way because it's alot more complicated then you think. It's mainly used when mass producing A/C systems, so basically when it's made.
Things you might get worried about, when adding refrigerant, at probably either the first or second can the manifold might get very very cold and condensate. This is normal.
Any questions ask me no problem
Old 07-21-2011, 01:38 AM
ramvan2500's Avatar
Rep:128
Cross referencing isn't always correct but I have the same exact valve and sure it comes in a collection of sizes however chrysler has a known reputation for using the same size everything. That and I've seen a few 97 rams in the junk yard and of course like to treasure hunt for A/c valves and lines etc...
Well if you cannot get the valve then send me you shipping address and I'll snaily maily you one for free.
Old 07-21-2011, 01:57 AM
sonocativo's Avatar
Rep:210
I know of some of the parts, a new dryer runs around $45 at Oreillys and they have the assortment of those green rubber o-rings, then the orifices I have no idea where they go...lol and I know there is a special tool to undo the lines but have no idea how to use it as well as the manifold. I know the ac doesnt get real cold as it should but it works enough to get me by so I know it needs a good vac and probly some real maintenance since it didnt work when I got it and started working when I added the can of leak/dye/oil... and topped it off with 134a. The can comes with a guage on it and the needle is in the filled marks. There is a guy that is local that will do the repairs cheap $60 for evac and fill + parts so I plan to have it done right soon, just getting the money up is the issue till then. Hopefully have it done in another week since I dont want to ruin anything. If I ever come to florida ( I have family there ) It would be great to meet and say Hi.
Mike
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
Valve Cover Leaking nauticstar 2110 Cummins Diesel Specific Topics 6 02-01-2011 09:35 PM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
