A/C low pressure valve leaking - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-08-2012, 09:15 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Well, been awhile and long overdue.... Finally found a schrader valve to fit, now the shop is ordering a shizload of caps since none they have fit as the inside diameter is larger than the old. Sorry I didnt get pics of the new valve yet but got dark out and only have a crappy cell pic to show.... Got it vac'd down to 28 for 2 hours and a 1 hour leakdown test of 0 so it stayed at 28....yah me ! The rent of the pump and manifold ran $279 but got that back when returned, the schrader valve ran me $10 and the 134a/PAG100 oil ran $85 for 32oz/oil as I needed the fill kit... heres some pics, enjoy.
Old Valve blow apart
New valve internal...next to old valve internals
Vac Pumped to 28 for 2 hours with 0 leak down after an hour
High pressure side during vac pump
I Am Groot !
Old 01-09-2012, 01:01 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Well you got it all fixed, I too have to replace the valves I actually have a crap load to do to the cooling. All my lines are steel and 16 years old so you can bet your butt they're rusted. So I have to sand them all down repaint. Have to replace filter, 2 expansion valves, O-Rings, the works. Errr, But once it's all fixed it should make it about a decade and I don't expect the vehicle to make it that much longer, Not drive wise but rust wise lol
Old 01-09-2012, 03:00 PM
sonocativo's Avatar
Rep:227
LOL the ole lead sleds.....made to last a lifetime.....well, almost !
I Am Groot !
Old 01-09-2012, 09:42 PM
ramvan2500's Avatar
Rep:141
Not quite a mercury sled, but close enough. Aside from the body and frame, the engine, transmission, and axle will last practically forever.
Old 04-28-2013, 05:27 PM
gm20061 gm20061 is offline
Vehicle: 1997 dodge ram
Color: red
gm20061 is on a distinguished road
I hope so, at least for the rest of this year... Here is the quick fix I did as a precaution...
What size bolt did you use(9mm, 10mm, etc)?
Old 06-02-2013, 09:22 PM
440sp 440sp is offline
Vehicle: 99 2500 4x4
Color: silver
440sp is on a distinguished road
There is a schraider valve inside the port....that's whats leaking you can buy replacement valves at auto zone and advance with the tool that removes/replaces the valve inside the port I know cause mines leaking also and I tightened it up but its still leaking slowly you will have to have the system pulled down and replace the valve and vac and refill....usually not very expensive since they will reuse what freon they capture from your system......cost will be for any freon added
Old 06-05-2013, 04:40 PM
sonocativo's Avatar
Rep:227
Ye, for the new style valves... The old one if you look at it was not replaceable, it is also aluminum and a POS !
Well the new style is awesome. Now, if I get this newer truck the ac needs fixed, probly same crap....lol I only hope
I Am Groot !
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Valve Cover Leaking nauticstar 2110 Cummins Diesel Specific Topics 6 02-01-2011 09:35 PM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
