Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 07-03-2011, 08:00 AM
farmall farmall is offline
Vehicle: 2003 3500 QC diesel
Color: Patriot blue
farmall is on a distinguished road
Default waht is EGR and should I delete?
Hey guys,
I have put in the DPF delete in and it appears to have helped my mileage problem. i have seen some talk about an EGR delete. What is an EGR? What are the advantages to disconnecting or deleteing? What is required to disconnect or delete?
Thanks
Old 07-03-2011, 12:22 PM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
I cant speak for the specifics of whats involved in doing a delete on the 5.9L.
EGR stands for Exhaust Gas Recirculation. A portion of your exhaust (up to 20% depending on the engine) is put back into your engines intake to be burned again. This in turn reduces the amount of NOx coming out of the tailpipe and in turn reducing your emissions.
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 07-03-2011, 12:41 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I'm hoping your have a 6.7l too because there isnt DPF filters or EGR on 5.9s
If your do your engine will run better and will be cleaner(internally) without the EGR
The EGR plates in a 6.7 were the most disgusting thing I've ever seen come out of a motor
Old 07-03-2011, 04:13 PM
Rep:12
I was thinking he bought a 07+ truck and hasnt updated the stats.
I think of EGR as forcing an engine to eat its own poop.
Old 07-03-2011, 09:42 PM
Color: Patriot blue
Sorry guys. I did buy a 2011 but I haven't been able to figure out how to update my profile. I have been learning a lot about changes people are making. i love the truck and have gotten rid of the DPF. It seems to have added about 2.5 miles per gallon but I would like to gain more if I can find it. That is why I was asking about the EGR. I didn't really know what is was for. Will the EGR delete help the longevity of the engine? Sounds like a bad practice (eating one's own poop)
Old 07-04-2011, 02:57 PM
Dooner's Avatar
Dooner Dooner is offline
Vehicle: 2010 Dodge Ram 3500 DRW 2wd
Color: PDA-Light Greystone Pearl
Rep:20
Dooner is on a distinguished road
Since it is an off road only mod, does anyone make a delete that still looks like the factory equipment? If they can't tell, you can't get in any trouble over it.
Dooner
2010 Dodge Ram 3500 DRW 2wd and 1964 Plymouth Belvedere 4dr Sedan
Old 07-05-2011, 07:28 PM
Dooner's Avatar
Rep:20
Did some digging and found some block off plates that retain the stock egr and cooler. Is this the way everyone is doing it (except for the racing guys)?
Dooner
Old 07-09-2011, 09:37 AM
Rep:12
Programmers like H&S allow you to disable the EGR from functioning.
Old 09-04-2011, 03:22 PM
flaxbourton flaxbourton is offline
Vehicle: 2010 Dodge Ram 2500
Color: White w/ Tan Strip
flaxbourton is on a distinguished road
I asked this in another thread, but since this is more focussed on the egr, I will ask again here. If you set your programmer to disable the EGR, I have read that you still should do the physical plate block. Is this true?
Also, to the OP, 2.5 mpg increase? This seems low compared to other feedback I have read. Do you have a tuner as well?
Old 09-08-2011, 08:50 PM
Sledneck's Avatar
Sledneck Sledneck is offline
Vehicle: 1998 Dodge Ram Club Cab 2 Door
Color: Midnight Blue
Sledneck is on a distinguished road
Its not a bad idea to still block the opening because those two butterfly valves will not always seal 100% so you could get some recirculation. If you dont want to get the tuner or plates and still get by, I pulled the wires from the egr and it fails closed. I noticed about 1.4 better mpg but I have a engine light. As soon as i put it back the light disappeared. It doesnt go into limp mod though.
